We are using Infragistics_WPF_20182a XamPivotGrid.and an AdomdConnectionSettings"XamPivotGrid.DataSource.ConnectionSettings = AdomdConnectionSettings.ConnectionString"
my question is about: when conect to a analysis services using AdomdConnectionSettings.ConnectionString and the DataSource is not a http:// but a server in this case the "User ID" parameter is ignored and it returns the error: "The user <My local user> has not access to the database"
If we connect to the server using: "Data Source=">server04:8090/.../msmdpump.dll" we have not problem.
This is the ConnectionString:
"Provider=MSOLAP.8;Password=XXX;Persist Security Info=True;User ID=XXXX;Initial Catalog=DATABASE;Data Source=server04;MDX Compatibility=1;Safety Options=2;MDX Missing Member Mode=Error;Update Isolation Level=2"
Hello Cristina,
I have been investigating into the behavior you are seeing, and it seems that this likely is not an Infragistics-specific issue, as our AdomdDataSource and AdomdConnectionSettings work directly with the Microsoft.AnalysisServices.AdomdClient.AdomdConnection object, in that we give the connection string that you pass to the AdomdDataSource and AdomdConnectionSettings to this object in order to actually make the connection to the database.
As such, if this is failing, I would have to believe that your connection string here is at fault. You could verify this by passing your connection string to a Microsoft.AnalysisServices.AdomdClient.AdomdConnection object and try to connect to your database that way, as I believe that this should result in the same error you are seeing. For more information on this, I would recommend taking a look at this article.
