15
xamBusyIndicator Loader Background
In case of  xamBusyIndicator SpinnerSegmentedBusyAnimation , I want the box type transparent background, so that the text below it Generating results should be shown more clear.
Link reffered : https://www.infragistics.com/help/wpf/xambusyindicator-configuring-animations-brushes
Reffered Code:
<ig:XamBusyIndicator IsBusy="True" Name="SpinnerSegmented" > <ig:XamBusyIndicator.Animation> <ig:SpinnerSegmentedBusyAnimation AnimationFill="#FF43A898" />
</ig:XamBusyIndicator.Animation> </ig:XamBusyIndicator>
Current Result :
Expected Result :
  • 34430
    Hello Anshu,
    I have been investigating into the behavior you are reporting, but using the code you have provided, I am seeing the correct color applied to the segmented ring of the XamBusyIndicator. It looks like you are trying to have a fully opaque result around the busy indicator animation in this case as well. If this is the case, you can set the Background on the XamBusyIndicator itself.
    I am attaching a sample project to demonstrate the above.
    BusyIndicatorBrushTest.zip
