I am binding a DataTable to a XamDataGrid and would like to have row names.
Can I have a manually added first column that binds to an observableCollection or is there some other way of doing this short of inserting it into the table?
thanks
Hello Terill,
Thank you for contacting. We do not have any row naming feature in the XamDataGrid but you are right you can add this name column through your datasource . or you can add it as unbound column to the grid .
To understand unbound column you can refer to this online help doc.
Or another way could be do column grouping ,explained here .
Let me know if you have further question or concern.
Regards
thank you. Those were very helpful links and problem is solved.
