I am using the datatype TreeViewItem to add to the XamDataTree and I am then adding Children of the same type.
The XamDataTree displays as hoped, but does not allow me to select the children items.
Do you know what property I need to set to allow the children to be individually selected?
Also, if there is an equivalent of a XamDataTreeItem I could switch to that,
thanks
Hello Terrill,
I have been investigating into this behavior you are seeing, and I believe this issue is due to the way that the .NET TreeViewItem enumerates its Items collection. It appears that the Nodes that are generated for the XamDataTree are generating a single node for parent and child items.
I feel that you may be misled on how the XamDataTree works in this case, though. It does not necessarily need to have a data source of a particular item such as the TreeViewItem or a comparable "XamDataTreeItem." As long as your data structure is hierarchical, you can use essentially any class with the XamDataTree.
I am attaching a sample project to demonstrate using a very simple custom class to create a hierarchical structure that allows individual selection of parent and child elements.
XamDataTreeChildSelectionTest.zip
thank you.
I would like to use Drag and Drop and that is why I wanted to pick a built in class like TreeViewItem
The XamDataTree has a built-in Drag and Drop functionality for its nodes, and you do not need to use TreeViewItem in order to have this functionality. You can view how to enable this here: https://www.infragistics.com/help/wpf/xamdatatree-xamdatatree-drag-and-drop.
Thank you!
