230
Set Button.IsEnabled to true if a data record in grid is selected.
I have a button on my window. I would like it to be enabled only if a data record in the grid has been selected. I would like to bind this up in a xaml line of code like this:
    IsEnabled="{Binding ElementName=EmailGrid, Path=HasSelectedRecord}"
Which property of the grid would I used for 'HasSelectedRecord' ?
Thx
Tom
  • 2125
    Hi TLangFromInfragistics,
    I would suggest the following solution:
    <Button  Grid.Row="1"
                  Height="23"
                  Margin="151,0,175,38"
                  Name="button1"
                  VerticalAlignment="Bottom"
                  IsEnabled="{Binding ElementName=xamDataGrid1, Path=SelectedItems.Records.Count,
                  Converter ={StaticResource dataConverter}}">
                  Button
    </Button>
    The attached ButtonEnabling sample application contains the full solution implementation.
    Best Regards,
    Yanko
    ButtonEnabling.zip
