I don't want to use xaml jut css or data info because the amount to doctors will be grabbed from a database. my code references a stored procedure named GetDoctors to grab a list of names and then another named Encounters that retrieves data if this format
Name | Date | encountertotal
Dr. A 1/1/2009 100
Dr. A 2/1/2009 105
Dr. A 3/1/2009 110
Dr. B 1/1/2009 102
Dr. B 2/1/2009 103
Dr. B 3/1/2009 98
I want the chart to be a line chart with encounter values up Y axis and Dates across X axis with the names of the doctors being the lines. Here is a code segment i'm using, but it only displays one line?
System.Data.DataTable DT2 = new System.Data.DataTable();
SqlCommand MyCommand2 = new SqlCommand("ClinicData.dbo.GetDoctors", MyConnection);
MyCommand2.CommandType = System.Data.
CommandType.StoredProcedure;
SqlDataAdapter MyDataAdapter2 = new SqlDataAdapter(MyCommand2);
MyDataAdapter2.Fill(DT2);
MyDataAdapter2.Dispose();
// NOW DT2 CONTAINS MY LIST OF DOCTORS
SqlCommand MyCommand = new SqlCommand("ClinicData.dbo.Encounters", MyConnection);
MyCommand.CommandType = System.Data.
SqlParameter sqlname = MyCommand.Parameters.Add(new SqlParameter("@name",System.Data.SqlDbType.NVarChar,254));
SqlParameter sqlstartdate = MyCommand.Parameters.Add(new SqlParameter("@startdate",System.Data.SqlDbType.SmallDateTime));
SqlParameter sqlenddate = MyCommand.Parameters.Add(new SqlParameter("@enddate",System.Data.SqlDbType.SmallDateTime));
sqlname.Direction = System.Data.ParameterDirection.Input;
sqlstartdate.Direction = System.Data.ParameterDirection.Input;
sqlenddate.Direction = System.Data.ParameterDirection.Input;
this.xamChart1.Series.Clear();
sqlstartdate.Value = startdate.SelectedDate;
sqlenddate.Value = startdate.SelectedDate;
// NOW DISPLAY SERIES FOR EACH DOCTOR
for (int lp = 0; lp < DT2.Rows.Count; lp++)
DT.Clear();
sqlname.Value = DT2.Rows[lp][0].ToString();
SqlDataAdapter MyDataAdapter = new SqlDataAdapter(MyCommand);
MyDataAdapter.Fill(DT);
MyDataAdapter.Dispose();
Infragistics.Windows.Chart.
Series MySeries = new Infragistics.Windows.Chart.Series();
this.xamChart1.Series.Add(MySeries);
this.xamChart1.Series[lp].DataMapping = "Label=name;Value=encountertotal";
this.xamChart1.Series[lp].ChartType = Infragistics.Windows.Chart.ChartType.Line;
this.xamChart1.Series[lp].DataSource = DT;
this.xamChart1.Series[lp].Label = DT2.Rows[lp][0].ToString();
this.xamChart1.Series[lp].Animation = new Infragistics.Windows.Chart.Animation();
No matter what I try, I end up with only one line. encounters are listed up the y axis and one name is displayed multiple times across the x axis.What am i doing wrong?
You can try changing the creation of the chart series to be something like:
for (int seriesIndex = 0; seriesIndex < 2; seriesIndex++) { Series series = new Series(); series.ChartType = Infragistics.Windows.Chart.ChartType.Line; this.xamChart1.Series.Add(series); int rowIndex = seriesIndex * 3; for (int lp = rowIndex; lp < 3 * (rowIndex + 1); lp++) { DataPoint dp = new DataPoint(); dp.Value = Convert.ToDouble(DT2.Rows[lp][2]); dp.Label = DT2.Rows[lp][1].ToString(); } }
