40
XamRibbonWindow problem
When using the following code on Windows XP and Windows Vista Ultimate, works fine.
<igRibbon:XamRibbonWindow>
   <Grid>
      <igRibbon:RibbonWindowContentHost
      x:Name="mainContentWindow">
   <igRibbon:RibbonWindowContentHost.Ribbon/>
   <igRibbon:RibbonWindowContentHost.StatusBar/>
</igRibbon:RibbonWindowContentHost>
   </Grid>
</igRibbon:XamRibbonWindow>
When using the same code on Windows Vista Home Premium, following error comes up:
‘ The object ‘RibbonWindowsContentHost’ can not be aggregated to ‘Grid’. Hwnd of zero is not valid. Error on object ‘Infragistics.Windows.Ribbon.RibbonWindowContentHost’ on file ….
Do you know why this happens?
  • 54837
    Verified Answer
    This sounds like an issue we addressed back in May that can happen on a system when running a vista system in vista basic. It should be addressed if you get the latest hotfix. If you cannot get the hotfix then you can contact the support group and mention issue #16346.
