Hi there,
We've been using the XamDataGrid for our data presentation for a while now, and it is totally up to scratch for what we need (and easy enough to work with), except for ONE thing...
The customer wants to be able to group grid headings under categories, so that conventional column headings basically become sub-headings.
In other words, there would be 2 heading rows, with the top row spanning multiple columns, and the second row's headings being one per column.
For example:
Is this possible in the XamDataGrid?
Reinhardt
Hello Reinhardt,
Yes, this is possible. For this, you have to use UnboundField and set their Column, Row, RowSpan, ColumnSpan properties. You also have to turn off the AutoArrangeFields property. You can see more information on how to do this here :
http://community.infragistics.com/forums/p/20411/80262.aspx#80262
Spate146 has also provided a sample application with this functionality.
Hope this helps.
