550
Picture Tab
I am trying to replace the tab headers with a picture and a name.  I can replace each header no problem.  The issue is I need to change the text color when the tab is selected.
Here is my header content so far:
            <igWindows:TabItemEx >
                <igWindows:TabItemEx.Header>
                    <StackPanel Height="70" Width="70">
                        <Image Source="..\images\transactions.png" Height="48" Width="48" />
                        <TextBlock Text="Transactions"   HorizontalAlignment="Center" />
                    </StackPanel>
                </igWindows:TabItemEx.Header>
            </igWindows:TabItemEx>
Is there a way to do this as a style or a template and set the triggers to change the text block's foregound color?
  • 69686
            <Style TargetType="{x:Type igWindows:TabItemEx}">
                <Setter Property="Template">
                    <Setter.Value>
                        <ControlTemplate TargetType="{x:Type igWindows:TabItemEx}">
                                <Image Source="{Binding Path=SomePath}" Height="48" Width="48" />
                                <TextBlock Text="{TemplateBinding Header}" Name="header"  HorizontalAlignment="Center" />
                            </StackPanel>
                            <ControlTemplate.Triggers>
                                <Trigger Property="IsSelected" Value="True">
                                    <Setter Property="Foreground" TargetName="header" Value="Red"/>
                                </Trigger>
                            </ControlTemplate.Triggers>
                        </ControlTemplate>
                    </Setter.Value>
                </Setter>
            </Style>
    Here is what you can use. The image you have to bind to some other property - for example, you can use the Tag property to store the path to the image.
  • 54937
    Verified Answer
    Offline posted in reply to Eric
    You could use the same approach I recommend here for adding an image to a tab using the HeaderTemplate and just add in a datatrigger based on the IsSelected of the tab item. e.g.
        <igWindows:XamTabControl>
            <igWindows:XamTabControl.Resources>
                <DataTemplate x:Key="tabItemHeader">
                    <DockPanel>
                        <igWindows:AutoDisabledImage
                            DockPanel.Dock="Left"
                            Source="{Binding Path=Tag,
                                RelativeSource={RelativeSource
                                    AncestorType={x:Type igWindows:TabItemEx}}}"
                            Margin="0,0,3,0" />
                        <TextBlock x:Name="txt" Text="{Binding}" VerticalAlignment="Center" />
                    </DockPanel>
                    <DataTemplate.Triggers>
                        <DataTrigger
                            Binding="{Binding Path=IsSelected,
                            Value="True">
                            <Setter TargetName="txt" Property="Foreground" Value="Red" />
                        </DataTrigger>
                    </DataTemplate.Triggers>
                </DataTemplate>
            </igWindows:XamTabControl.Resources>
            <igWindows:TabItemEx Header="Home" HeaderTemplate="{StaticResource tabItemHeader}">
                <igWindows:TabItemEx.Tag>
                    <BitmapImage UriSource="/Images/about_16.bmp" />
                </igWindows:TabItemEx.Tag>
            <igWindows:TabItemEx Header="Other" HeaderTemplate="{StaticResource tabItemHeader}">
        </igWindows:XamTabControl>
