105
Checkbox and EditModeEnding
I've got a xamdatagrid bound to a custom object. One of the fiels is a bool and as the default...the grid is using the xamcheckeditor as the control. That is all working fine. However, I need to know when the box is checked and unchecked so I can set AllowEdit on some fields depending on true or false. Here is my xaml....I wanted to use the EditModeEnding...and according to the checkeditor I should be able to specifiy that...however...I don't see that as an allowable parameter to set...any advice?
igDP:Field x:Name="UDFNameDataGridColIsDiscreet" Name="IsDiscreet" Label="Is Discreet?"
<igDP:Field.Settings
<igDP:FieldSettings CellWidth="150" LabelTextWrapping="WrapWithOverflow" AllowGroupBy="False"
</igDP:Field.Settings
</igDP:Field
