Good day.
I have the following problem. I want record filtering on and header placement at top only, but the grid does not behave like to should.
This image is the problem.
HeaderPlacementInGroupBy="OnTopOnly"
AllowRecordFiltering="True"
HeaderPlacementInGroupBy="Default"
AllowRecordFiltering="False"
What I want is a combination between image 2 and 3. But they combine wrong...
I want image 2's filtering and image 3's header placement.
Is this a bug? I'm using version 9.2
Kind regards
Christo Labuschagne
Hi Christo,
I believe we had such an issue here and it was resolved. Can you please download the latest service release and try with it?
Sincerely,
Horen Kirazyan
Cool!
I'll download it and try. I'll verify your answer if it worked.
Christo
Hi
I am facing a similar issue with the record filtering on and with multiple layouts (2 to be exact).
We are using 2010.3 (.net 3.5). Has this issue been resolved or is there any other workaround for this?
