I followed the instructions here: http://help.infragistics.com/Help/NetAdvantage/WPF/2010.2/CLR4.0/html/xamDataPresenter_Binding_a_DataPresenter_Control_to_a_DataSet.html to bind my grid to a DataSet. But when I click on the drop down box on the filter it throws an InvalidOperationException.
Message: "Collection was modified; enumeration operation may not execute."
Source: PresentationFramework
StackTrace: at System.Windows.Data.CollectionView.PlaceholderAwareEnumerator.MoveNext()
my code looks like:
private DataSet dsDummyData;
public void CreateDummyData(int NumRowsToCreate) { dsDummyData = new DataSet(); dsDummyData.Tables.Add("testData"); dsDummyData.Tables["testData"].Columns.Add("Price"); var list = new List<object[]>(); for (double i = NumRowsToCreate; i > 0; i--) { var priceData = new object[1]; priceData[0] = i; list.Add(priceData); } foreach (var objectse in list) { dsDummyData.Tables["testData"].Rows.Add(objectse); } } private void UserControl_Loaded(object sender, RoutedEventArgs e) { CreateDummyData(10); if (dsDummyData.Tables["testData"] != null) { this.myGrid.DataSource = dsDummyData.Tables["testData"].DefaultView; } }
What am I missing?
Normal 0 false false false EN-GB X-NONE X-NONE MicrosoftInternetExplorer4
I have recently upgraded to 11.1 infragistics from 2010. I am used to having exception free code and therefore I catch all thrown exceptions when debugging.
After upgrading to 2011 from 2010 I am seeing lots of exceptions which did not use to be there. They appear randomly as I activate rows, row filter or try editing cells in xamDataGrid.
All exceptions are handled I just want to point out the different behaviour in your code which used to be exception free on WPF 2010.3.
System.InvalidOperationException occurred
Message=Collection was modified; enumeration operation may not execute.
Source=PresentationFramework
StackTrace:
last callstack from infragistics library before calling PresentationFramework.dll
PresentationFramework.dll!System.Windows.Data.CollectionView.OnCollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs args) Line 1126 + 0xc bytes C#
InfragisticsWPF4.v11.1.dll!Infragistics.Collections.ObservableCollectionExtended<Infragistics.Windows.DataPresenter.FilterDropDownItem>.OnCollectionChanged(System.Collections.Specialized.NotifyCollectionChangedEventArgs e) + 0x12 bytes
InfragisticsWPF4.v11.1.dll!Infragistics.Collections.ObservableCollectionExtended<Infragistics.Windows.DataPresenter.FilterDropDownItem>.EndUpdate() + 0x92 bytes
InfragisticsWPF4.DataPresenter.v11.1.dll!Infragistics.Windows.DataPresenter.ResolvedRecordFilterCollection.FilterDropDownItemLoader.PopulatePhase1() + 0x13a bytes
