How do i have tooltip for axis label. On hovering the tooltip should show label value.
I tried setting the tooltip value using the below xaml. But it is not working. Please help.
<igCA:Axis AxisType="PrimaryX"> <igCA:Axis.Label> <igCA:Label ToolTip="subrat"/> </igCA:Axis.Label> </igCA:Axis>
see: http://community.infragistics.com/forums/p/45102/244751.aspx#244751
Any workaround?
Not that I'm aware of, but I'll get back to you if I have any neat ideas. I should note that if you use the XamDataChart, you have much more control over the axis labels, so you may want to see if that is compatible with your requirements.
-Graham
