I would like if it is possible to display gantt chart in your WPF data chart.
I was thinking of a few possible ways. One would be to uses stacked (step) area with the bottom area transparent but this would not be very efficient as it would require to have a lot more data per displayed bar than a predefined gantt (range bar) chart.
Another way might be to use stacked Y axis and uses one Y axis for each series and then uses step area for that serie.
It might also be possible to uses range area but it would require to add twice as much points to the series.
I want that the solution be as memory efficient as possible and typically a zoom on time axis (X) would be done to show one day (or less) data but we might have a few month of data. I might have about 10 series (tasks) that are repeatable and might occurs up to a few hundred times per day.
I might dynamically update series as the user scroll if it is required to have a good performance (be responsive when the user scroll) as I was doing with WinForms In fragistics gantt chart. When the user scroll, I do not want to have noticeable latency on a typical recent computer.
I am still evaluating a few chart components. Infragistics xamDataChart seems to be more complete that most packages but miss Gantt series (or range bars) and have a few other issues.
It may be possible to emulate one with a range area series, I'll get back to you.
Here's a start of how you might emulate a gantt chart over a scatter chart. There are various things that you would extend here to get better performance, they have been left as an excercise to the reader. This sample may also not encompass some of the functionality you would expect from a gantt chart, obviously, but I hope you find it useful:
The Xaml:
<Window.Resources> <local:TestGanttData1 x:Key="data1" /> <local:TestGanttData2 x:Key="data2" /> <local:TestGanttData3 x:Key="data3" /> </Window.Resources> <Grid> <local:LiteGanttChart x:Name="gantt" MinimumValue="1/1/2010" MaximumValue="1/12/2010" Interval="1.00:00:00"> <local:LiteGanttChart.GanttToolTip> <Border Background="White" BorderBrush="Gray" BorderThickness="1" IsHitTestVisible="False" > <StackPanel> <StackPanel Orientation="Horizontal"> <TextBlock Text="{Binding Item.StartTime, StringFormat=MM/dd}" /> <TextBlock Text=" - " /> <TextBlock Text="{Binding Item.EndTime, StringFormat=MM/dd}" /> </StackPanel> <TextBlock Text="{Binding Item.Description}" /> </StackPanel> </Border> </local:LiteGanttChart.GanttToolTip> <local:LiteGanttChart.Series> <local:GanttSeries TaskName="Task1" StartTimeMemberPath="StartTime" EndTimeMemberPath="EndTime" ItemsSource="{StaticResource data1}" /> <local:GanttSeries TaskName="Task2" StartTimeMemberPath="StartTime" EndTimeMemberPath="EndTime" ItemsSource="{StaticResource data2}" /> <local:GanttSeries TaskName="Task3" StartTimeMemberPath="StartTime" EndTimeMemberPath="EndTime" ItemsSource="{StaticResource data3}" /> </local:LiteGanttChart.Series> </local:LiteGanttChart> </Grid>
And the code behind:
public partial class MainWindow : Window { public MainWindow() { InitializeComponent(); } } public class GanttSeries : FrameworkElement { public GanttSeries() { Data = new ObservableCollection<LiteGanttData>(); } public static readonly DependencyProperty TaskNameProperty = DependencyProperty.Register("TaskName", typeof(string), typeof(GanttSeries), new PropertyMetadata(null, (o, e) => (o as GanttSeries).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public string TaskName { get { return (string)GetValue(TaskNameProperty); } set { SetValue(TaskNameProperty, value); } } public static readonly DependencyProperty TaskValueProperty = DependencyProperty.Register("TaskValue", typeof(double), typeof(GanttSeries), new PropertyMetadata(-1.0, (o, e) => (o as GanttSeries).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public double TaskValue { get { return (double)GetValue(TaskValueProperty); } set { SetValue(TaskValueProperty, value); } } public static readonly DependencyProperty BrushProperty = DependencyProperty.Register("Brush", typeof(Brush), typeof(GanttSeries), new PropertyMetadata(null, (o, e) => (o as GanttSeries).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public Brush Brush { get { return (Brush)GetValue(BrushProperty); } set { SetValue(BrushProperty, value); } } public static readonly DependencyProperty StartTimeMemberPathProperty = DependencyProperty.Register("StartTimeMemberPath", typeof(string), typeof(GanttSeries), new PropertyMetadata(null, (o, e) => (o as GanttSeries).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public string StartTimeMemberPath { get { return (string)GetValue(StartTimeMemberPathProperty); } set { SetValue(StartTimeMemberPathProperty, value); } } public static readonly DependencyProperty EndTimeMemberPathProperty = DependencyProperty.Register("EndTimeMemberPath", typeof(string), typeof(GanttSeries), new PropertyMetadata(null, (o, e) => (o as GanttSeries).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public string EndTimeMemberPath { get { return (string)GetValue(EndTimeMemberPathProperty); } set { SetValue(EndTimeMemberPathProperty, value); } } public static readonly DependencyProperty ItemsSourceProperty = DependencyProperty.Register("ItemsSource", typeof(IEnumerable), typeof(GanttSeries), new PropertyMetadata(null, (o, e) => (o as GanttSeries).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public IEnumerable ItemsSource { get { return (IEnumerable)GetValue(ItemsSourceProperty); } set { SetValue(ItemsSourceProperty, value); } } private FastItemsSource _fastItemsSource; protected FastItemsSource FastItemsSource { get { return _fastItemsSource; } set { FastItemsSource old = _fastItemsSource; _fastItemsSource = value; OnPropertyChanged("FastItemsSource", old, _fastItemsSource); } } protected internal IFastItemColumn<DateTime> StartTimeColumn { get { return _startTimeColumn; } private set { if (_startTimeColumn != value) { IFastItemColumn<DateTime> oldStartTimeColumn = _startTimeColumn; _startTimeColumn = value; OnPropertyChanged("StartTimeColumn", oldStartTimeColumn, _startTimeColumn); } } } private IFastItemColumn<DateTime> _startTimeColumn; protected internal IFastItemColumn<DateTime> EndTimeColumn { get { return _endTimeColumn; } private set { if (_endTimeColumn != value) { IFastItemColumn<DateTime> oldEndTimeColumn = _endTimeColumn; _endTimeColumn = value; OnPropertyChanged("EndTimeColumn", oldEndTimeColumn, _endTimeColumn); } } } private IFastItemColumn<DateTime> _endTimeColumn; public ObservableCollection<LiteGanttData> Data { get; private set; } private void OnPropertyChanged(string propertyName, object oldValue, object newValue) { switch (propertyName) { case "StartTimeMemberPath": if (oldValue != null && FastItemsSource != null) { FastItemsSource.DeregisterColumn(StartTimeColumn); StartTimeColumn = null; } if (newValue != null && FastItemsSource != null) { StartTimeColumn = FastItemsSource.RegisterColumnDateTime( StartTimeMemberPath); } ResetData(); break; case "EndTimeMemeberPath": if (oldValue != null && FastItemsSource != null) { FastItemsSource.DeregisterColumn(EndTimeColumn); EndTimeColumn = null; } if (newValue != null && FastItemsSource != null) { EndTimeColumn = FastItemsSource.RegisterColumnDateTime( EndTimeMemberPath); } ResetData(); break; case "TaskName": OnNameChanged(); ResetData(); break; case "TaskValue": ResetData(); break; case "ItemsSource": if (newValue != null) { FastItemsSource source = new FastItemsSource(); source.ItemsSource = (IEnumerable)newValue; FastItemsSource = source; } else { FastItemsSource = null; } break; case "FastItemsSource": if (oldValue != null) { (oldValue as FastItemsSource).Event -= source_Event; if (StartTimeColumn != null) { (oldValue as FastItemsSource) .DeregisterColumn(StartTimeColumn); StartTimeColumn = null; } if (EndTimeColumn != null) { (oldValue as FastItemsSource) .DeregisterColumn(EndTimeColumn); EndTimeColumn = null; } } if (newValue != null) { (newValue as FastItemsSource).Event += source_Event; if (StartTimeMemberPath != null) { StartTimeColumn = (newValue as FastItemsSource) .RegisterColumnDateTime(StartTimeMemberPath); } if (EndTimeMemberPath != null) { EndTimeColumn = (newValue as FastItemsSource) .RegisterColumnDateTime(EndTimeMemberPath); } } ResetData(); break; } } public LiteGanttChart Owner { get; set; } private void OnNameChanged() { if (Owner != null) { Owner.ResetSeries(); } } void source_Event(object sender, FastItemsSourceEventArgs e) { //excersize to the reader, do something more //efficient here. ResetData(); } private void ResetData() { Data.Clear(); if (FastItemsSource != null && StartTimeColumn != null && EndTimeColumn != null && StartTimeColumn.Count == EndTimeColumn.Count && EndTimeColumn.Count == FastItemsSource.Count && !String.IsNullOrEmpty(TaskName) && TaskValue >= 0) { for (int i = 0; i < FastItemsSource.Count; i++) { foreach (var item in GetLiteGanttData( StartTimeColumn[i], EndTimeColumn[i])) { Data.Add(item); } } } } private IEnumerable<LiteGanttData> GetLiteGanttData( DateTime startTime, DateTime endTime) { LiteGanttData preceding = new LiteGanttData() { Task = TaskName, StartTime = startTime, EndTime = endTime, Time = startTime.AddMilliseconds(-1), Value = double.NaN }; yield return preceding; LiteGanttData start = new LiteGanttData() { Task = TaskName, StartTime = startTime, EndTime = endTime, Time = startTime, Value = TaskValue }; yield return start; LiteGanttData end = new LiteGanttData() { Task = TaskName, StartTime = startTime, EndTime = endTime, Time = endTime, Value = TaskValue }; yield return end; LiteGanttData succeeding = new LiteGanttData() { Task = TaskName, StartTime = startTime, EndTime = endTime, Time = endTime.AddMilliseconds(1), Value = double.NaN }; yield return succeeding; } } public class LiteGanttData : INotifyPropertyChanged { private string _task; public string Task { get { return _task; } set { _task = value; RaisePropertyChanged("Task"); } } private DateTime _startTime; public DateTime StartTime { get { return _startTime; } set { _startTime = value; RaisePropertyChanged("StartTime"); } } private DateTime _endTime; public DateTime EndTime { get { return _endTime; } set { _endTime = value; RaisePropertyChanged("EndTime"); } } private DateTime _time; public DateTime Time { get { return _time; } set { _time = value; RaisePropertyChanged("Time"); } } private double _value; public double Value { get { return _value; } set { _value = value; RaisePropertyChanged("Value"); } } private void RaisePropertyChanged(string propertyName) { if (PropertyChanged != null) { PropertyChanged(this, new PropertyChangedEventArgs( propertyName)); } } public event PropertyChangedEventHandler PropertyChanged; } public class TaskNameConverter : IValueConverter { public object Convert( object value, Type targetType, object parameter, System.Globalization.CultureInfo culture) { if (parameter == null || !(parameter is string)) { return ""; } string[] names = ((string)parameter).Split(','); if (!(value is double)) { return ""; } double val = (double)value; int index = (int)val; index--; if (targetType == typeof(string) && index >= 0 && index < names.Length) { return names[index]; } return ""; } public object ConvertBack( object value, Type targetType, object parameter, System.Globalization.CultureInfo culture) { throw new NotImplementedException(); } } public class TicksToDateTimeConverter : IValueConverter { #region IValueConverter Members object IValueConverter.Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture) { return new DateTime(Convert.ToInt64(value)).ToString("MM/dd"); } object IValueConverter.ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture) { return ((DateTime)value).Ticks; } #endregion } public class LiteGanttChart : ContentControl { private Grid _grid = new Grid(); private XamDataChart _chart = new XamDataChart(); public static readonly DependencyProperty MinimumValueProperty = DependencyProperty.Register("MinimumValue", typeof(DateTime), typeof(LiteGanttChart), new PropertyMetadata(DateTime.MinValue, (o, e) => (o as LiteGanttChart).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); private void OnPropertyChanged(string propertyName, object oldValue, object newValue) { switch (propertyName) { case "MaximumValue": ResetSeries(); break; case "MinimumValue": ResetSeries(); break; case "Interval": ResetSeries(); break; } } public DateTime MinimumValue { get { return (DateTime)GetValue(MinimumValueProperty); } set { SetValue(MinimumValueProperty, value); } } public static readonly DependencyProperty MaximumValueProperty = DependencyProperty.Register("MaximumValue", typeof(DateTime), typeof(LiteGanttChart), new PropertyMetadata(DateTime.MaxValue, (o, e) => (o as LiteGanttChart).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public DateTime MaximumValue { get { return (DateTime)GetValue(MaximumValueProperty); } set { SetValue(MaximumValueProperty, value); } } public static readonly DependencyProperty IntervalProperty = DependencyProperty.Register("Interval", typeof(TimeSpan), typeof(LiteGanttChart), new PropertyMetadata(TimeSpan.MaxValue, (o, e) => (o as LiteGanttChart).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public TimeSpan Interval { get { return (TimeSpan)GetValue(IntervalProperty); } set { SetValue(IntervalProperty, value); } } public static readonly DependencyProperty GanttToolTipProperty = DependencyProperty.Register("GanttToolTip", typeof(UIElement), typeof(LiteGanttChart), new PropertyMetadata(null, (o, e) => (o as LiteGanttChart).OnPropertyChanged( e.Property.Name, e.OldValue, e.NewValue))); public UIElement GanttToolTip { get { return (UIElement)GetValue(GanttToolTipProperty); } set { SetValue(GanttToolTipProperty, value); } } public LiteGanttChart() { _series = new GanttSeriesCollection(); Series.CollectionChanged += Series_CollectionChanged; _chart = CreateChart(); HorizontalContentAlignment = HorizontalAlignment.Stretch; VerticalContentAlignment = VerticalAlignment.Stretch; Content = _grid; _grid.Children.Add(_chart); _chart.SeriesMouseEnter += _chart_SeriesMouseEnter; _chart.SeriesMouseMove += _chart_SeriesMouseMove; _chart.SeriesMouseLeave += _chart_SeriesMouseLeave; } private Popup _popup = null; void _chart_SeriesMouseLeave(object sender, ChartMouseEventArgs e) { HidePopup(); } private void HidePopup() { if (_popup == null) { return; } _popup.IsOpen = false; } void _chart_SeriesMouseMove(object sender, ChartMouseEventArgs e) { GanttDataContext context = GetGanttDataContext(e); UpdatePopup(e.GetPosition(this), context); } private GanttDataContext GetGanttDataContext(ChartMouseEventArgs e) { if (e.Series == null) { return null; } var ganttSeries = Series[_chart.Series.IndexOf(e.Series)]; var ganttDataContext = new GanttDataContext(); ganttDataContext.GanttSeries = ganttSeries; ganttDataContext.Series = e.Series; var scatter = e.Series as ScatterLineSeries; if (scatter == null) { return null; } var pos = e.GetPosition(scatter); double xVal = scatter.XAxis.GetUnscaledValue(pos.X, _chart.WindowRect, new Rect(0, 0, scatter.XAxis.ActualWidth, scatter.XAxis.ActualHeight)); List<LiteGanttData> data = new List<LiteGanttData>(ganttSeries.Data); data.Sort((item1, item2) => item1.Time.CompareTo(item2.Time)); int i; for (i = 0; i < data.Count; i++) { if (data[i].Time > new DateTime((long)xVal)) { break; } } if (i > 0) { i--; } int index = ganttSeries.Data.IndexOf(data[i]); index = index / 4; if (ganttSeries.ItemsSource is IList) { ganttDataContext.Item = ((IList)ganttSeries.ItemsSource)[index]; } return ganttDataContext; } private void UpdatePopup( Point point, GanttDataContext dataContext) { if (GanttToolTip == null) { return; } if (dataContext == null) { return; } if (_popup == null) { _popup = new Popup(); _grid.Children.Add(_popup); } _popup.Child = GanttToolTip; _popup.DataContext = dataContext; _popup.PlacementTarget = _grid; _popup.Placement = PlacementMode.Relative; _popup.VerticalOffset = point.Y + 10; _popup.HorizontalOffset = point.X + 10; _popup.IsOpen = true; } void _chart_SeriesMouseEnter(object sender, ChartMouseEventArgs e) { GanttDataContext context = GetGanttDataContext(e); UpdatePopup(e.GetPosition(this), context); } private XamDataChart CreateChart() { XamDataChart chart = new XamDataChart(); var xAxis = new NumericXAxis(); var yAxis = new NumericYAxis(); chart.Axes.Add(xAxis); chart.Axes.Add(yAxis); return chart; } void Series_CollectionChanged( object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e) { foreach (var series in Series) { series.Owner = this; } ResetSeries(); } internal void ResetSeries() { _chart.Series.Clear(); int i = 1; var xAxis = _chart.Axes.OfType<NumericXAxis>().First(); if (this.ReadLocalValue(MinimumValueProperty) != DependencyProperty.UnsetValue) { xAxis.MinimumValue = MinimumValue.Ticks; } if (this.ReadLocalValue(MinimumValueProperty) != DependencyProperty.UnsetValue) { xAxis.MaximumValue = MaximumValue.Ticks; } if (this.ReadLocalValue(IntervalProperty) != DependencyProperty.UnsetValue) { xAxis.Interval = Interval.Ticks; } string xaml = @"<DataTemplate xmlns=""http://schemas.microsoft.com/winfx/2006/xaml/presentation"" xmlns:x=""http://schemas.microsoft.com/winfx/2006/xaml"" xmlns:local=""clr-namespace:@@Namespace;assembly=@@Assembly"" > <DataTemplate.Resources> <local:TicksToDateTimeConverter x:Key=""converter"" /> </DataTemplate.Resources> <TextBlock Text=""{Binding Item, Converter={StaticResource converter}}"" /> </DataTemplate>"; xaml = xaml.Replace( "@@Namespace", typeof(TicksToDateTimeConverter).Namespace); xaml = xaml.Replace( "@@Assembly", typeof(TicksToDateTimeConverter).Assembly.FullName); DataTemplate template = XamlReader.Parse(xaml) as DataTemplate; if (template == null) { return; } xAxis.Label = template; var yAxis = _chart.Axes.OfType<NumericYAxis>().First(); yAxis.LabelSettings = new AxisLabelSettings() { Extent = 50, HorizontalAlignment = System.Windows.HorizontalAlignment.Right }; yAxis.MinimumValue = 0; yAxis.MaximumValue = Series.Count + 1; yAxis.Interval = 1; var names = from series in Series select series.TaskName; StringBuilder taskNames = new StringBuilder(); bool first = true; foreach (var name in names) { if (first) { first = false; } else { taskNames.Append(","); } taskNames.Append(name); } xaml = @"<DataTemplate xmlns=""http://schemas.microsoft.com/winfx/2006/xaml/presentation"" xmlns:x=""http://schemas.microsoft.com/winfx/2006/xaml"" xmlns:local=""clr-namespace:@@Namespace;assembly=@@Assembly"" > <DataTemplate.Resources> <local:TaskNameConverter x:Key=""converter"" /> </DataTemplate.Resources> <TextBlock Text=""{Binding Item, Converter={StaticResource converter}, ConverterParameter='@@Names'}"" /> </DataTemplate>"; xaml = xaml.Replace( "@@Namespace", typeof(TaskNameConverter).Namespace); xaml = xaml.Replace( "@@Assembly", typeof(TaskNameConverter).Assembly.FullName); xaml = xaml.Replace( "@@Names", taskNames.ToString()); template = XamlReader.Parse(xaml) as DataTemplate; if (template == null) { return; } yAxis.Label = template; foreach (var ganttSeries in Series) { var series = CreateSeries(ganttSeries, i); _chart.Series.Add(series); i++; } } private ScatterLineSeries CreateSeries(GanttSeries ganttSeries, int index) { ganttSeries.TaskValue = index; var series = new ScatterLineSeries(); series.XAxis = _chart.Axes.OfType<NumericXAxis>().First(); series.YAxis = _chart.Axes.OfType<NumericYAxis>().First(); series.XMemberPath = "Time"; series.YMemberPath = "Value"; series.ItemsSource = ganttSeries.Data; series.MarkerType = MarkerType.None; series.Thickness = 20; series.SetBinding(ScatterLineSeries.TitleProperty, new Binding("TaskName") { Source = ganttSeries, Mode = BindingMode.OneWay }); series.SetBinding(ScatterLineSeries.BrushProperty, new Binding("Brush") { Source = ganttSeries }); return series; } private GanttSeriesCollection _series; public GanttSeriesCollection Series { get { return _series; } } } public class GanttDataContext { public GanttSeries GanttSeries { get; set; } public Series Series { get; set; } public object Item { get; set; } } public class GanttSeriesCollection : ObservableCollection<GanttSeries> { } public class TestGanttDataItem { public DateTime StartTime { get; set; } public DateTime EndTime { get; set; } public string Description { get; set; } } public class TestGanttData1 : ObservableCollection<TestGanttDataItem> { public TestGanttData1() { Add(new TestGanttDataItem() { StartTime = new DateTime(2010, 1, 2), EndTime = new DateTime(2010, 1, 3), Description = "test1" }); Add(new TestGanttDataItem() { StartTime = new DateTime(2010, 1, 4), EndTime = new DateTime(2010, 1, 6), Description = "test2" }); } } public class TestGanttData2 : ObservableCollection<TestGanttDataItem> { public TestGanttData2() { Add(new TestGanttDataItem() { StartTime = new DateTime(2010, 1, 2), EndTime = new DateTime(2010, 1, 4), Description = "test3" }); Add(new TestGanttDataItem() { StartTime = new DateTime(2010, 1, 5), EndTime = new DateTime(2010, 1, 7), Description = "test4" }); } } public class TestGanttData3 : ObservableCollection<TestGanttDataItem> { public TestGanttData3() { Add(new TestGanttDataItem() { StartTime = new DateTime(2010, 1, 3), EndTime = new DateTime(2010, 1, 4), Description = "test5" }); Add(new TestGanttDataItem() { StartTime = new DateTime(2010, 1, 8), EndTime = new DateTime(2010, 1, 11), Description = "test6" }); } }
Hope this helps!
-Graham
A screenshot of what the above produces:
This is a nice start and it would be nice to include this sample it in the "Feature Browser".
For the code above, you might just add the #using in the code-behind and namespace declaration in the xaml so that it would directly compile in a new project.
I haven't yet tried this sample with a lot of points and zoom/scroll functionality but this might be something you might eventually add.
I'll forward it along to our product guidance staff and, if they like it, maybe it will appear in the next version of the feature browser.
I use a tool called Resharper that automatically fills in using directives, so sometimes it slips my mind that others may need to do a bit of hunting to track the right directives down. Also, as many of the namespaces relate to the name of my sample project, it can often cause more harm than help for them to be copied into someones pre-existing project. In general, as long as you have the correct assemblies already referenced, the object browser (View -> Object Browser) is your friend here. You can just type in a type name into the search box and, if located, you can see the namespace which contains the type pretty swiftly.
If you add lots of points to the sample you may need to raise the value of the MaximumMarkers property on the underlying scatter line series to a higher figure, or it will start removing points to conserve performance.
By the way, you can control the zoom level of the chart programatically, which strikes me as something you would want to do in this case, to keep the task names and time intervals legible. This is handled via the use of the chart's WindowRect property. The width and height of the WindowRect range from 0 to 1 and represent the percentage of the total chart that is visible. The top and left of the WindowRect represent the percentage offset (from 0 to 1) from the top left of the chart to position the viewing window.
In the sample I'm locking the interval on both axes to a fixed value. The y axis because it is emulating a category axis, and the x axis because it is emulating a time axis and I wanted the intervals to be nice even time intervals. If you add a lot of data to the chart, since these intervals are fixed, you might start to see these labels overlap. One solution to this would be to keep the window zoomed into a level that made viewing these attractive (letting the user pan around to see more of the values), and another would be to change the intervals as the zoom level changes (you can handle an event to warn you of this) to omit some labels when the chart is more zoomed out. Normally the chart is doing this sort of thing for you automatically. But the semantics of how this is done for the NumericYAxis and the NumericXAxis don't cleanly map into their being used for category or time data.
As part of the changes we have in the pipeline for 11.1 we are releasing a bar series that has a dependency on a CategoryYAxis, which may give a cleaner way to emulate a gantt series y axis.
Another area that you would want to fill out is what happens when the underlying data gets updated. For brevity, this sample is simply reconstructing all the gantt emulation data, rather than just reconstructing the data that changed, so if your data is very dynamic, or, for example, you put some draggable thumbs on the gantt items to change their width, you would want to flesh out the update semantics to do less work, if the performance started to degrade.
