558
Color Cells
I have a XamDataGrid with a few fields in it: ID, Name, Amount.  Amount has the value plus the change.  For example, Amount = "100 (-10)".  I want to color the -10 based on some other conditions.  I tried to pass html, <p>100 <span style="color: red">-10</span></p> but that formatting does not apply.  Is there a way to tell the grid that the cells are to be html code?  Or is there an alternate route?  I used to apply styling based on a converter but the logic to determine whether the cell should be colored is fairly complex.
Kyle
  • 14517
    The following article describes creating a WPF HTML Supported Textbox.
    http://www.codeproject.com/KB/WPF/htmltextblock.aspx
    You could implement something along these lines and then create a style for the CellValuePresenter and set the Template to a control template using the HTML text box, then set the CellValuePresenterStyle on the field to use that style.
     Sincerely,
    Valerie
    Developer Support Engineer
    www.infragistics.com/support
