Good day
We are using Infragistics3.Wpf.v9.2 and I get an error when filtering on a column with a ComboBoxItemsProvider to show a code list. The correct item shows in the filter combobox (eg rejected) but when you select is, the error occurs. Should this not work?
Kind regards
Chris2L
Some code
<igEditors:ComboBoxItemsProvider x:Key="cbFKState" ItemsSource="{Binding Source={StaticResource odpHotworkS_State}}" DisplayMemberPath="State" ValuePath="IdState"> </igEditors:ComboBoxItemsProvider>
<igDP:Field Name="FKState" Label="State"> <igDP:Field.Settings> <igDP:FieldSettings LabelMinWidth="50" CellMinWidth="50" CellWidth="100" LabelWidth="100" EditorType="{x:Type igEditors:XamComboEditor}"> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamComboEditor}"> <Setter Property="ItemsProvider" Value="{StaticResource cbFKState}" /> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:Field>
Hi Stefan
In the mean time I think I installed the SR1 and upgraded to VS2010 and .net 4, and now the problem seems resolved
Thank you very much for your time in trying to resolve my issue.
Hello Chris,
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post but I wasn’t able to reproduce your behavior. I tested your scenario with version 9.2 but it seems like everything works ok on my side. If this is still an issue for you could you please provide me with a sample project so I can investigate it further for you.
