I want to achieve the following task through MVVM:
I have a xamDatagrid with columns having values on which graph can be represented.
I select few of these values from DataGrid and want to represent Graph at runtime.
Now, I want these selected values in ViewModel, which I was able to achieve through Interaction DLL's.
Now, I want to update or populate the graph with these values at runtime. - which I'm not able to achieve.
I hope the situation is pretty much clear.
Please tell me, how can I achieve this task.
VJ
I suppose no-one has the answer for this question or probably would be searching on how to do this. I have partially acheived this thing, when everything will be working fine, I'll post the code here.
Just for reference I have used and modified the code at below link.
http://community.infragistics.com/forums/p/38169/219968.aspx#219968
The code you have linked to would have been my recommendation. Also if MVVM scenarios are important to you, I encourage you to submit a feature request detailing how you would like the api of the chart to better support this.
Thanks!
-Graham
