I am new with VS2010 and WPF.
I am starting an existing project and I have the error : Tag "XamDockManager" does not exist in XML-Namespace "http://infragistics.com/DockManager" nicht vorhanden
How can I add this?.
A Snippet from my code:
<UserControl x:Class="LkwWalter.Routing.PCClient.Controls.MainControl" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:igDock="http://infragistics.com/DockManager" d:DesignHeight="300" d:DesignWidth="900"> <UserControl.Resources> <ResourceDictionary> <ResourceDictionary.MergedDictionaries> <ResourceDictionary Source="Dictionary1.xaml" /> </ResourceDictionary.MergedDictionaries> </ResourceDictionary> </UserControl.Resources> <Grid Name="LayoutRoot" Background="Transparent" > <igDock:XamDockManager Name="xamDockManager1" Theme="Aero" LayoutMode="FillContainer" Background="Transparent">
It sounds like you didn't add a reference to the xamDockManager assembly (e.g. for CLR4 using the NA 2010.3 release that would be InfragisticsWPF4.DockManager.v10.3.dll). You may want to start by going through the getting started section of the help.
Note you might also get a similar message if you're in a CLR3 (e.g. target framework for the project is 3.5) and you're referencing the CLR4 assemblies (i.e. the ones that start with InfragisticsWPF4) instead of the CLR3 assemblies (the ones that start with InfragisticsWPF3).
I think this is what I need.
I have installed the .NET Framework 4 but I can not found the Infragistics3.Wpf.. under the .NET tab in the Add Reference dialog box to add it.
What version of our NetAdvantage product did you install? Note starting with the NetAdvantage 2010 Volume 2 release the assemblies were renamed to start with "InfragisticsWPF" so assuming you installed (presumably a trial version) our WPF LOB product you would see references like InfragisticsWPF4.v10.3.dll, InfragisticsWPF4.DockManager.v10.3.dll, etc.
I installed the NetAdvantage for WPF Line of Business 2010 Vol. 3 Product Only in a trial version
Now I have no Problem with the reference of the .dll files but a CL.exe exits with code -1
I think is an other reason.
Thank You it helps
I'm not sure what the problem would be then. Maybe you can post the sample project you are creating so we can see the issue.
