We are using xamDataGrid to show multiple columns in a window as attached below. You can see that Number is the first fixed column. After that there are multiple Unbound columns. In the below screen shot we could see 3 and half columns but we still have 10 columns. Again we have some fixed columns.
Now our question is, When I move the scroll bar the unbound columns will get moved, not the Number and second set of fixed columns. But When I try to drag any unbound column to move the position of the column within the set of unbound columns(Not to the fixed column). It is not getting moved. To get the movement I suppose to drag out of the grid boundary. Is there any way to restrict the boundary with in the grid, So that whenever I move the column out of the unbound column, it grid should start scroll to place it in another place.
Hope I have not confused. Please revert for any queries.
Thanks!
Best Regards,
Saravanan GR.
HI,
It would be very helpful if you could provide a small sample application and detailed steps to reproduce.
Sincerely, Matt Developer Support Engineer
Please let me know if you need further assistance regarding this case.
Sincerely, MattDeveloper Support Engineer
