305
Crash when loading layout
I'm getting crashes when loading layouts with xamDockManager.  The layout has lots of windows in it.  Stack trace points to ToolWindow and Transparency.
exception:
The thread tried to read from or write to a virtual adress for which it dos not have the appropriate access
Stack Track:
     [Managed to Native Transition]
     InfragisticsWPF4.v11.2.dll!Infragistics.Windows.Controls.ToolWindowHostWindow.HookProc(int nCode, System.IntPtr wParam, System.IntPtr lParam) + 0x9d bytes
     [Native to Managed Transition]
     WindowsBase.dll!MS.Win32.UnsafeNativeMethods.CreateWindowEx(int dwExStyle, string lpszClassName, string lpszWindowName, int style, int x, int y, int width, int height, System.Runtime.InteropServices.HandleRef hWndParent, System.Runtime.InteropServices.HandleRef hMenu, System.Runtime.InteropServices.HandleRef hInst, object pvParam) + 0x3c bytes
     WindowsBase.dll!MS.Win32.HwndWrapper.HwndWrapper(int classStyle, int style, int exStyle, int x, int y, int width, int height, string name, System.IntPtr parent, MS.Win32.HwndWrapperHook[] hooks) + 0x382 bytes
     PresentationCore.dll!System.Windows.Interop.HwndSource.Initialize(System.Windows.Interop.HwndSourceParameters parameters) + 0x276 bytes
     PresentationFramework.dll!System.Windows.Window.EnsureHiddenWindow() + 0xf7 bytes
     PresentationFramework.dll!System.Windows.Window.SetTaskbarStatus() + 0x51 bytes
     PresentationFramework.dll!System.Windows.Window.CreateAllStyle() + 0x3d bytes
     PresentationFramework.dll!System.Windows.Window.CreateSourceWindow(bool duringShow) + 0x13e bytes
     PresentationFramework.dll!System.Windows.Window.CreateSourceWindowDuringShow() + 0xa bytes
     PresentationFramework.dll!System.Windows.Window.SafeCreateWindowDuringShow() + 0x40 bytes
     PresentationFramework.dll!System.Windows.Window.ShowHelper(object booleanBox) + 0x81 bytes
     PresentationFramework.dll!System.Windows.Window.Show() + 0x61 bytes
     InfragisticsWPF4.v11.2.dll!Infragistics.Windows.Controls.ToolWindowHostWindow.Show(bool activate) + 0x29 bytes
     InfragisticsWPF4.v11.2.dll!Infragistics.Windows.Controls.ToolWindowHostWindow.DeferShowHelper.Show(bool activate) + 0x7c bytes
     InfragisticsWPF4.v11.2.dll!Infragistics.Windows.Controls.ToolWindow.DeferredShowInfo.ProcessShow(bool cancel) + 0x52 bytes
     InfragisticsWPF4.v11.2.dll!Infragistics.Windows.Controls.ToolWindow.DeferredShowInfo.System.IDisposable.Dispose() + 0x7 bytes
     InfragisticsWPF4.v11.2.dll!Infragistics.Windows.Controls.ToolWindow.Reshow() + 0xa2 bytes
     InfragisticsWPF4.v11.2.dll!Infragistics.Windows.Controls.ToolWindow.OnSupportsAllowsTransparencyChanged() + 0x74 bytes
     InfragisticsWPF4.DockManager.v11.2.dll!Infragistics.Windows.DockManager.PaneToolWindow.VerifyPreventAllowsTransparencyImpl() + 0xd0 bytes
     mscorlib.dll!System.Delegate.DynamicInvokeImpl(object[] args) + 0x77 bytes
     WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs) + 0xae bytes
     WindowsBase.dll!MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(object source, System.Delegate method, object args, int numArgs, System.Delegate catchHandler) + 0x42 bytes
     WindowsBase.dll!System.Windows.Threading.DispatcherOperation.InvokeImpl() + 0x8d bytes
     WindowsBase.dll!System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(object state) + 0x38 bytes
     mscorlib.dll!System.Threading.ExecutionContext.runTryCode(object userData) + 0x51 bytes
     mscorlib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state) + 0x6a bytes
     mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool ignoreSyncCtx) + 0x7e bytes
     mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state) + 0x2c bytes
     WindowsBase.dll!System.Windows.Threading.DispatcherOperation.Invoke() + 0x68 bytes
     WindowsBase.dll!System.Windows.Threading.Dispatcher.ProcessQueue() + 0x15e bytes
     WindowsBase.dll!System.Windows.Threading.Dispatcher.WndProcHook(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) + 0x63 bytes
     WindowsBase.dll!MS.Win32.HwndWrapper.WndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) + 0xbe bytes
     WindowsBase.dll!MS.Win32.HwndSubclass.DispatcherCallbackOperation(object o) + 0x7d bytes
     WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs) + 0x53 bytes
     WindowsBase.dll!System.Windows.Threading.Dispatcher.InvokeImpl(System.Windows.Threading.DispatcherPriority priority, System.TimeSpan timeout, System.Delegate method, object args, int numArgs) + 0xb4 bytes
     WindowsBase.dll!MS.Win32.HwndSubclass.SubclassWndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam) + 0x104 bytes
     WindowsBase.dll!System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame frame) + 0xc1 bytes
     WindowsBase.dll!System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame frame) + 0x49 bytes
     PresentationFramework.dll!System.Windows.Application.RunDispatcher(object ignore) + 0x5b bytes
     PresentationFramework.dll!System.Windows.Application.RunInternal(System.Windows.Window window) + 0x74 bytes
     PresentationFramework.dll!System.Windows.Application.Run(System.Windows.Window window) + 0x2b bytes
>    Zetta.exe!RCS.ZettaUI.App.Main() Line 263 + 0x2c bytes    C#
     00050003()
     user32.dll!_DispatchHookW@16()  + 0x38 bytes
     user32.dll!___fnHkINLPCBTCREATESTRUCT@4()  + 0xa7 bytes
     ntdll.dll!_KiUserCallbackDispatcher@12()  + 0x2e bytes
     user32.dll!_NtUserCreateWindowEx@60()  + 0x15 bytes
     user32.dll!_VerNtUserCreateWindowEx@52()  + 0x18a bytes
     user32.dll!__CreateWindowEx@52()  + 0xd4 bytes
     user32.dll!_CreateWindowExW@48()  + 0x33 bytes
     user32.dll!_InternalCallWinProc@20()  + 0x23 bytes
     user32.dll!_UserCallWinProcCheckWow@32()  + 0xb7 bytes
     user32.dll!_DispatchMessageWorker@8()  + 0xed bytes
     user32.dll!_DispatchMessageW@4()  + 0xf bytes
     mscoreei.dll!__CorExeMain@0()  + 0x38 bytes
     mscoree.dll!_ShellShim__CorExeMain@0()  + 0x227 bytes
     mscoree.dll!__CorExeMain_Exported@0()  + 0x8 bytes
     kernel32.dll!@BaseThreadInitThunk@12()  + 0x12 bytes
     ntdll.dll!___RtlUserThreadStart@8()  + 0x27 bytes
     ntdll.dll!__RtlUserThreadStart@8()  + 0x1b bytes
  • 138253
    Thank you for your post. I have been looking into it, but I wasn’t able to reproduce your behavior, so if this is still an issue for you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you.
  • 138253
