Hi
I have two tabs.
one is Dashboard Tab and other is Task Tab.
My task is if I select one receord based on "ID" I need to show "Task Tab" with data.
with initial load i am able to load the data. I am using WCF service to call the Method.
But I am able to see the data in the property , but some how its not reflecting on the View xamdatagrid.
Please help me with this. I am unable to attach my full project.
Thanks in advance,
with regards,
Sarma
4045363884
attached TaskTypeViewModel
attached view
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post, but it seems like that I am missing something in your scenario, and without an isolated sample I cannot be completely sure what can cause your behavior, so if this is still an issue for you, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
