I am using sample code given in this post to save and load Pivot Grid layout. Although given code works just fine for a single hierarchy on an axis but it doesn't load second hierarchy at all. For better illustration see below screenshots.
Saved with following configuration:
When loaded back, I got following:
Can somebody help me?
Thank you!
Hello Abdullah,
Thank you for your post. I have been looking into it and I can say that this issue has been fixed in the latest service releases of versions 12.1, 12.2 and 13.1, so I can suggest you download the latest service release for the one you use by logging to our web site and going to Account \Keys & Downloads.logging to our web site and going to Account \Keys & Downloads.
Hope this helps you.
Hi Stefan,
I am already on 12.2 yet sample doesn't work as expected.
Thank you,
Abdullah Atta
Can you please verify if you are using the latest service release (12.2.20122.2179) and if not I can suggest you donload it and try with it.
Thank you for your help. The problem has been solved by the latest service release, now two or more hierarchies are loading correctly. Besides this issue, I am facing two more issues.
1) Sample code doesn't remember expansion state correctly. It expands all the levels in the hierarchy when loaded back.
2) I want to save and load column width as well but when I set column width when loading, it doesn't apply correctly and column gets squeezed or expanded in width.
I am attaching sample code that I am using. I have made some customization to it according to my requirements.
After some research Save/Load Cells width has been determine as a new Product Idea. I have sent your Product Idea directly to our product management team. Our product team chooses new Product Ideas for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested ideas, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your idea is chosen for development, you will be notified at that time. Your reference number for this Product Idea is PI13050150
If you would like to follow up on your Product Idea at a later point, you may contact Developer Support management via email. Please include the reference number of your Product Idea in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
As for the expansion states, you can check the sample in the Samples Browser under xamPivotGrid / Data / Save and Load Data Source Customizations section, where the expansion states are loaded correctly.
