I tried to run the sample application using xambarcode for QR code reader from webcam. on click of decode button, its not showing any results. let me know how to fix it.
Thnaks & Regards
Pradeep
Hi Pradeep,
How are you presenting the QR code in front of the camera? Is the QR code printed on a piece of paper and held up to the webcam or do you have the QR code on a smartphone and you're holding that up to the webcam? If you're using a smartphone it might have some difficulties if you don't turn down the screen brightness. Even then it might be too bright.
If you're using a printed image on a piece of paper, can you send me the image you printed it from so I can test this?
This issue is being handled in a private case which you had opened. The case number is CAS-120795-G3H7D9.
