Hi ,
Advance thanks.
I am trying to show more than 15 columns in xamdatagrid. My client screen resolution is 1280x1024.
I must use xamdatagrid since my all other screens are using xamdatagrid and this particular screen doesn't like to look different .
Any link or guidance are much appreciated in this regards. I know it sounds crazy but this is the situation i am facing now.
Can you send me any link or suggestion which is handling multiple columns in xamdatagrid.
Is it possible a single cell can show multiple labels and multiple different controls .
My required fields are below
Address Type (drop down)
Address 1 (text box)
Address 2 (text box)
Country (dropdown)
Zip (textbox)
Zip1(textbox)
Zip2 (textbox)
City (textbox)
State (dropdown)
County (textbox)
Flag1(checkbox)Flag 2(checkbox)
Comments (textbox)
i DON'T KNOW HOW TO ASSIGN POINTS, OTHERWISE I WOULD HAVE ASSIGNED 1000 POINTS..
Kind regards,
Suresh
Hello Suresh,
Thank you for your post. I have been looking into it and I can suggest you see the sample in the Samples Browser under xamDataGrid / Display / XamComboEditor in DataRecord Cells section, which shows how to embed a dropdown list into the cells of a XamDataGrid Records. Please let me know if this helps you or you need further assistance on this matter.
Hi Stefan,
Can you send me the link? Sorry for the inconvenience.
The Samples Browser should be installed on your computer along with the NetAdvatage. You can found it here by default:
C:\Users\Public\Documents\Infragistics\NetAdvantage 2013.1\WPF\Samples\CLR4.0\Binaries\Infragistics.SamplesBrowser.exe
Also you can see the code for the sample here:
http://www.infragistics.com/products/wpf/sample/data-grid/xamcomboeditor-in-datarecord-cells
but since it is for WPF, you cannot interact with it, you can just see a screenshot of the sample and the XAML and C# code.
Hope this helps you.
Thanks for the support. We can close this issue since am not going to use xamdatagrid instead apply regular grid form controls.
