1915
Disabling XamDataGrid XamComboEditor field in MVVM way
I need to be able to make a XamDataGrid XamComboEditor read only in mvvm way through binding to a boolean property in a view model. I cant seem to get this to work by simple binding AllowUpdate to this boolean field in FieldSettings, for some reason the field drop down remains active if I bind it to a view model boolean variable. However if I just set AllowUpdate ="False" the field is disabled. Here is my code:
<igDP:Field Label="F1" Name="F1">
    <igDP:Field.Settings>
        <igDP:FieldSettings AllowEdit="{Binding IsEnabled}" EditorType="{x:Type igEditors:XamComboEditor}">
             <igDP:FieldSettings.EditorStyle>
             </igDP:FieldSettings.EditorStyle>
        </igDP:FieldSettings>
   </igDP:Field.Settings>
</igDP:Field>
