Hi Austin,
Thank you for your post. I have been looking into your issue and I am not sure how exactly you have implemented your asynchronous updating of the data in your XamDataGrid.
Could you please attach a sample application that shows your approach in order to investigate what exactly may cause the reported issue?
I am just checking, if this is still an issue for you.
Let me know, if you need any further assistance on this matter.
Thank you for your reply. I have been applied the provided style for the XamDataGrid and I still cannot produce the reported issue. It seems that you have not added the ‘NullIsTrue’ converter which is used in the second condition of your MultiDataTriggers.
Maybe I am missing something but in your first post you are explaining that you are updating asynchronously your data source with additional data. Does it mean that the XamDataGrid is empty in the beginning and the data template is not applied at this moment because I suppose that after that the XamDataGrid has always records?
I am attaching a sample application(DataGridBindingDataTemplate.zip) that I used for my tests. It would be high appreciated it you modified it in order to meet exactly your scenario in order to be able to reproduce the issue on my side and provide you with more accurate assistance on this matter. It is not necessary to use exactly you real data.
