450
Issue with command activation in MVVM project
We have a strange issue with command bindings on a XamMenuItem withing our MVVM project. If "StaysOpenOnClick" is set to false, the command bound to the item isn't activated. If it's set to true, it works. We've attached a small sample project that demonstrates the issue (only "ZoomInCommand" fires). We could of course manually close the menu, but that seems pointless if there is an attribute that should do the same thing. Is this an error on our side?
TestXamContextMenu.zip
