250
Cannot resolve dependency to assembly 'InfragisticsWPF4.v11.1
I have a WPF application that is using infragistics.
It works fine on the developers machine since it has infragistics installed on our machines.
However, while trying to build the application on a machine that does not have infragistics installed on it. The build fails with the below error.
Unknown build error, 'Cannot resolve dependency to assembly 'InfragisticsWPF4.v11.1, Version=11.1.20111.1002, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' because it has not been preloaded. When using the ReflectionOnly APIs, dependent assemblies must be pre-loaded or loaded on demand through the ReflectionOnlyAssemblyResolve event.
The application just uses XamComboEditor in its WPF form and has infragistics referenced in the page as follows:
 xmlns:igEditors="clr-namespace:Infragistics.Windows.Editors;assembly=InfragisticsWPF4.Editors.v11.1"
The project containing the form has reference to "InfragisticsWPF4.v11.1.dll" added from a commonlib folder not GAC.
The common lib folder also has reference to the below files:
Infragistics.Windows.Extensions.dll
InfragisticsWPF4.Controls.Editors.XamCalendar.v11.1.dll
InfragisticsWPF4.Controls.Schedules.v11.1.dll
InfragisticsWPF4.DataManager.v11.1.dll
InfragisticsWPF4.DataPresenter.ExcelExporter.v11.1.dll
InfragisticsWPF4.DataPresenter.v11.1.dll
InfragisticsWPF4.DockManager.v11.1.dll
InfragisticsWPF4.Editors.v11.1.dll
InfragisticsWPF4.Ribbon.v11.1.dll
Not sure why the project does not build and also not able . Please help....
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
