Hello Together,
I am trying to implement a XamCarouselListBox in my solution and encounter several minor problems, which I will split by topic into several messages here.
At the moment, I want to navigate through the Carousel with Drag (Mouse) or at best, Touch with a touchscreen (which works for standard ListBox-Items in WPF out of the box). A similar post from 2008 was refered as a "new feature" request. Has anything changed since then? Is there an easy solution for this?
Thanks a lot,
Florian
Hello Florian
This functionality is still not implemented and I can suggest you follow the suggestions given here:
http://www.infragistics.com/community/forums/t/1623.aspx
for implementing this by your own. You can also suggest this as new product idea at http://ideas.infragistics.com.
There are many benefits to submitting an product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
4. Include a link to this thread in your idea so product management will be able to look back at this case.
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics.
Hello Florian,
I am just checking if require any assistance or clarification on the matter.
