960
Showing Shortcuts in XamMenuItem Text
Hi, I've found that I can add Keyboard Shortcuts to execute commands using inputbindings inside the control
<ig:XamDataTree.InputBindings>
 <KeyBinding Key="F5" Command="{x:Static lcmd:SolutionProjectCommands.RefreshTree}" />
</ig:XamDataTree.InputBindings>
Using the code above the F5 shortcut correctly calls the command. My XamDataTree has also a context menu, so I wondered if there is a way to let the context menu elements the shorcut associated with their command to display its value to the user, when the menu is shown:
Reload (F5)
Can be the text of my command for example.
