45
Unable to cast object of type System.Windows.Data.BindingExpression to type Infragistics.Windows.Editors.ComboBoxItemsProvider
I keep recieving the Unable to cast object of type 'System.Windows.Data.BindingExpression' to type 'Infragistics.Windows.Editors.ComboBoxItemsProvider' error. The only way I can remove the error is to remove the ComboEditorTool,.
<ribbon:XamRibbon.QuickAccessToolbar>
ribbon:QuickAccessToolbar Background="Transparent">
ribbon:QatPlaceholderTool TargetId="propertyLabel"/>
ribbon:QatPlaceholderTool TargetId="propertySelector"/>
ribbon:QuickAccessToolbar>
ribbon:XamRibbon.ToolsNotInRibbon>
ribbon:ButtonTool IsEnabled="False" BorderBrush="Transparent" BorderThickness="0" Content="Property Selector" Id="propertyLabel"/>
ribbon:ComboEditorTool Id="propertySelector" x:Name="propertySelector" IsEditable="True"
DropDownResizeMode="VerticalOnly" EditAreaWidth="250"/>
List<Entity> entities = new List<Entity>();
entities = GetAllEntities();
entities.Sort(
delegate(Entity e1, Entity e2) { return e1.EntityName.CompareTo(e2.EntityName); });
this.formsDock.Children.Clear();
if (entities.Count <= 0)
PropertyFormControl form = new PropertyFormControl();
this.formsDock.Children.Add(form);
return;
entities.Insert(0, new Entity(-1, "", " -- All Locations --", "", ""));
ComboBoxItemsProvider itemsProvider = new ComboBoxItemsProvider();
itemsProvider.ItemsSource = entities;
itemsProvider.DisplayMemberPath =
"EntityName";
itemsProvider.ValuePath =
"EntityId";
propertySelector.SelectedItemChanged +=
new RoutedPropertyChangedEventHandler<object>(propertySelector_SelectedItemChanged);
propertySelector.ItemsProvider = itemsProvider;
propertySelector.SelectedIndex = 0;
  • 45
    If anyone else experiences this problem, be sure you have installed .NET Framework 3.0 SP1. I didn't realize that the new computer I was provided didn't already have it installed.
  • 5
    Hi, jmantheiy
    One of our user is experiencing very similar problem(exception attached).  This issue is very hard to reproduce.  I cannot find too much useful information in the internet until i found your post which is pretty close to the problem at our hand now.
      I am very interested to know
    1) What's the nature of your bug?  Is it .NET framework related or Infragistics related.
    2) What's the solution?
     I am very appreicated to have any feedback you can give.
     Thanks a lot
     Ming
    Unhandled exception occured, Exception='System.InvalidCastException: Unable to cast object of type 'System.Windows.Data.BindingExpression' to type 'System.IConvertible'.   at System.Convert.ToBoolean(Object value, IFormatProvider provider)   at MorganStanley.IED.Passport.Windows.IntegerToVisibilityConverter.Convert(Object value_, Type targetType_, Object parameter_, CultureInfo culture_) in c:\dev\buildshelf\ied\ied\Passport\2008.3-prod\src\assemblies\IED.PassportWindows\IntegerToVisibilityConverter.cs:line 56   at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)   at System.Windows.Data.BindingExpression.Activate(Object item)   at System.Windows.Data.BindingExpression.AttachToContext(AttachAttempt attempt)   at System.Windows.Data.BindingExpression.AttachOverride(DependencyObject target, DependencyProperty dp)   at System.Windows.Data.BindingExpressionBase.OnAttach(DependencyObject d, DependencyProperty dp)   at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal)   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)   at System.Windows.Data.BindingOperations.SetBinding(DependencyObject target, DependencyProperty dp, BindingBase binding)   at System.Windows.FrameworkElement.SetBinding(DependencyProperty dp, BindingBase binding)
