85
ScatterLineSeries ToolTip is not working
this ScatterLineSeries ToolTip is not working.
               <ig:ScatterLineSeries      ItemsSource="{StaticResource GaugeData}"
                                          MarkerType="Automatic"
                                          MarkerBrush="Transparent"
                                          MarkerOutline="Transparent"
                                          XMemberPath="X"
                                          YMemberPath="Y"
                                          Title="Gauge[mm]"
                                          Legend="{x:Reference GaugeLegend}"
                                          XAxis="{x:Reference gaugeXAxis}"
                                          YAxis="{x:Reference gaugeYAxis}"
                                          Brush="green">
                        <ig:ScatterLineSeries.ToolTipTemplate>
                            <DataTemplate>
                                <StackLayout VerticalOptions="End" Orientation="Vertical" Margin="5">
                                        <StackLayout Orientation="Horizontal">
                                            <Label Text="X= " FontSize="12"/>
                                            <Label Text="{Binding Item.X}" FontSize="12"/>
                                        </StackLayout>
                                            <Label Text="Y= " FontSize="12"/>
                                            <Label Text="{Binding Item.Y}" FontSize="12"/>
                                        </StackLayout>
                                 </StackLayout>
                            </DataTemplate>
                        </ig:ScatterLineSeries.ToolTipTemplate>
               </ig:ScatterLineSeries>
Can you help me?
  • 28950
    Verified Answer
    Hello Giovanni,
    The Scatter-based series in the XamDataChart in Infragistics for Xamarin.Forms does not currently support tooltips at the moment. This is documented at the following article, where there is a note stating that tooltips are not currently supported for Polar or Scatter series: https://www.infragistics.com/help/xamarin/datachart-chart-tooltips.
    The current issue in this case is that the internal Infragistics.Controls.DataContext type that is assigned as a BindingContext to your elements that you place in your ToolTipTemplate is not currently assigned an Item when using Scatter and Polar series, and so unlike the category-based series, the Item property that you are binding to will consistently return null. If your data is of a linear structure, I would heavily recommend utilizing a LineSeries if you need to show tooltips in the Infragistics for Xamarin.Forms XamDataChart control.
    I believe this will be implemented in a future version of Infragistics for Xamarin.Forms, but if you would like to make your desire for this feature heard, I would recommend suggesting a new product idea for it by e-mailing ideas@infragistics.com. This will place you in direct communication with our product management teams who plan and prioritize upcoming features and development based on community and user feedback.
    Sincerely,
    Andrew
    Associate Developer
