We are using XamlRadialGuage that has extra white space at bottom. How can we reduce this white speace in bottom. the code is <ig:XamRadialGauge HorizontalOptions="FillAndExpand" VerticalOptions="FillAndExpand" HeightRequest="160" MinimumValue="0" x:Name="RadialGauge" MaximumValue="200" Value="{Binding CommissionSummaryData[0].EarningsAttainment}" BackingShape="Fitted" BackingBrush="Transparent" BackingCornerRadius="10" Axis.X.Extent = "10" Axis.Y.Extent = "10" ScaleBrush = "#EEEEEE" TickStrokeThickness="0" MinorTickStrokeThickness="0" BackingStrokeThickness="0" LabelExtent="0.9" LabelInterval="100" FormatLabel="FormatRadialGaugeLabelHandler" ScaleStartAngle="200" ScaleEndAngle="340" NeedleShape = "Needle" NeedleStartExtent="0" NeedleEndExtent="0.8" NeedleBrush="#CBC7C7" NeedleOutline="#FFFFFF" NeedlePivotBrush="#CBC7C7" NeedlePivotOutline="#CBC7C7" > <ig:XamRadialGauge.Ranges> <ig:RadialGaugeRange Brush="#D74324" StartValue="0" EndValue="100" OuterStartExtent="0.8" OuterEndExtent="0.8" InnerStartExtent="0.3" InnerEndExtent="0.3"/> <ig:RadialGaugeRange Brush="#42AEAF" StartValue="100" EndValue="200" OuterStartExtent="0.8" OuterEndExtent="0.75" InnerStartExtent="0.3" InnerEndExtent="0.3"/> </ig:XamRadialGauge.Ranges> </ig:XamRadialGauge>
Hello Narendra,
By default, the XamRadialGauge in Xamarin.Forms will evaluate its size as if it will be a full circle, and so the extra space that you are seeing at the bottom of your gauge is actually expected in this case. In order to work around this, I would recommend utilizing the Scale property inherited from VisualElement in Xamarin.Forms to scale up your XamRadialGauge such that it appears "X" times its normal size.
You can then modify the CenterX and CenterY properties of your XamRadialGauge to reposition the center of the gauge using a value between 0 and 1 (by default this is 0.5, 0.5). Since you have constrained the height of your XamRadialGauge to 160 in this case, this should allow you to essentially remove the white space at the bottom of the gauge.
I have attached a sample project to demonstrate the above. I hope this helps you.
RadialGaugeSpace.zip
