when using the DarkMetro theme, the node lines are not drawn correctly. See attached image.
Using v16.1
Hello Markus,
Thank you for contacting Infragistics. I was not able to reproduce the behavior. I've attached a sample and I'd like you to please update and send it back to me and I will investigate this further. Please see my attachment and let me know if you have any questions.
I modified your example with a 3rd node level. Here you can see it. Just open the first node with its sub nodes.
See attached image.
Thank you for following up. I've reproduced the behavior, but note 16.1 is retired and no longer maintained. Any fixes will be made in the previous version onward. For more details please visit
https://www.infragistics.com/support/product-lifecycle
I have created case for you with ID CAS-18835-S9T7B8 to follow up with you during our investigation. The development issue logged is 246144. You could reach your case following the link bellow:
https://www.infragistics.com/my-account/support-activity I will update you via the mentioned case, so if you have any further questions or comments please update your case.
