Infragistics Community Forum / Web / Ignite UI for jQuery / how do i put line breaks inside iggrid
Jessica J
Jessica J asked on Jan 14, 2014 3:33 PM
my iggrid takes in data that has line breaks but it just shows up as one line. how can I make it multi-line with respect to the line breaks?
    Martin Pavlov
    Martin Pavlov answered on Jun 3, 2013 10:34 AM
    Hello Jessica,
    The grid data is rendered as pure HTML, so you'll need to use <br/> tag instead of line breaks.
    One way to achieve this is to use column formatter function and replace the "\n" character with "<br/>".
    Here is an example code:
    formatter: function(val) {
    return val.replace(/\n/g, "<br/>");
    Hope this helps,
    Martin Pavlov
      Jessica J
      Jessica J answered on Jun 3, 2013 1:49 PM
      I had <br/> tags in the database content that it pulls from, but it just displays "<br/>" instead of rendering it as an actual line break.
      It renders as javascript in mine. I'm not sure if you meant the same thing.
      <script type="text/javascript">$.ig.loader('igGrid.Paging.Resizing.Sorting', function() {$('#Grid1').igGrid({ dataSource: '/Products/GetContentData',autoGenerateColumns: false,autoGenerateLayouts: false,responseDataKey: 'Records', generateCompactJSONResponse: false, enableUTCDates: true, columns: [ { key: 'SKU', headerText: 'SKU', dataType: 'string', width: '150px' }, { key: 'ImageURL', headerText: 'Image', dataType: 'string', template: '<img src="${ImageURL}" style=\'width:100px;\' />', width: '110px' }, { key: 'Manufacturer', headerText: 'Manufacturer', dataType: 'string' }, { key: 'ProductType', headerText: 'Product Type', dataType: 'string' }, { key: 'Description', headerText: 'Name', dataType: 'string', template: '${Description}', width: '450px' }, { key: 'CoId', headerText: ' ', dataType: 'string', template: '<form action=\'/Orders/CreateOrderFromSku\' method=\'post\'><input type=\'hidden\' name=\'coId\' value=\'${CoId}\'/><input type=\'hidden\' name=\'partnerCoId\' value=\'${PartnerCoId}\'/><input type=\'hidden\' name=\'documentType\' value=\'Order\'/><input type=\'hidden\' name=\'portal\' value=\'true\'/><input type=\'hidden\' name=\'sku\' value=\'${SKU}\'/>{{if ${PartnerCoId} == 0 }}<input type=\'submit\' value=\'Add to Order\' disabled=\'disabled\' />{{else}}<input type=\'submit\' value=\'Add to Order\'/>{{/if}}</form>', width: '120px' }, { key: 'PartnerCoId', headerText: ' ', dataType: 'string', template: '<a href="/Products/ProductDetail?productId=${Id}&sku=${SKU}&partnerCoId=${PartnerCoId}" ><input type=\'button\' value=\'View Details\' /></a>', width: '120px' } ], features: [ { recordCountKey: 'TotalRecordsCount', pageIndexUrlKey: 'page', pageSizeUrlKey: 'pageSize', name: 'Paging', type: 'remote', pageSize: 10 }, { name: 'Resizing', allowDoubleClickToResize: true, deferredResizing: false }, { sortUrlKey: 'sort', sortUrlKeyAscValue: 'asc', sortUrlKeyDescValue: 'desc', name: 'Sorting', mode: 'single' } ], initialDataBindDepth: 0, primaryKey: 'SKU', width: '100%', height: '520px', localSchemaTransform: false });});</script>
        Martin Pavlov
        Martin Pavlov answered on Jun 3, 2013 2:19 PM
        Hi Jessica,
        You see the "<br/>", because it is HTML encoded by the MVC framework. By default any submitted data is HTML encoded.
        What I wanted to say was that you should add a formatter property to the column which data needs to be split into line breaks.
        Here is an example code for the "Description" column:
        key: 'Description',
        headerText: 'Name',
        dataType: 'string',
        //template: '${Description}',
        width: '450px',
        This code will replace the new line character with the "<br/>" string. In your case if you have HTML encoded "<br/>" string then you may want to replace the "&lt;br/&gt;" string with "<br/>".
        Hope this helps,
        Martin Pavlov
        Jessica J
        Jessica J answered on Jun 3, 2013 3:05 PM
        I'm creating the grid in # and it's throwing me a javascript undefined error. I'm not sure what I'm doing wrong.
         gridModel.Columns.Add(new GridColumn
                                                  Key = "Description",
                                                  HeaderText = "Name",
                                                  DataType = "string",
                                                  FormatterFunction = "replaceLineBreaks('${Description}')",
                                                  Width = "450px"
            function replaceLineBreaks(val) {
                return val.replace("\r\n", "<br/>");
        Martin Pavlov
        Martin Pavlov answered on Jun 3, 2013 3:27 PM
        Hello Jessica,
        Try with the following code:
        Controller code:
        FormatterFunction = "replaceLineBreaks",
        Width = "450px"
        View code:
        </script>
        Hope this helps,
        Martin Pavlov
        Jessica J
        Jessica J answered on Jun 3, 2013 3:28 PM
        So I got part of it working with this
                                                  FormatterFunction = "function(val) {return val.replace(/\\r\\n/g, '&lt;br/&gt;');}",
                                                  Width = "450px"
        However, the <br tag still shows up as "<br/>" and not as a line break. It's still coming in as HTML encoded.
        Martin Pavlov
        Martin Pavlov answered on Jun 3, 2013 3:34 PM
        Hello Jessica,
        Can you post some example data which is populated in the Description column.
        You can also try to use the following code:
        FormatterFunction = "function(val) {return val.replace('&lt;br/&gt;', '<br/>');}",
        Best regards,
        Martin Pavlov
        Jessica J
        Jessica J answered on Jun 3, 2013 3:39 PM
        This is actually the code, the <> got replaced somehow in the previous post. It's displaying as "<br/>"
                                                  FormatterFunction = "function(val) {return val.replace(/\\r\\n/g, '<br/>');}",
                                                  Width = "450px"
        In the database I had this separated with linebreaks
        "blah
        blah"
        and this is how it comes in to the code
        "blah\r\n   blah"
        Martin Pavlov
        Martin Pavlov answered on Jun 3, 2013 4:12 PM
        Hello Jessica,
        You should check how this new line is serialized in the JSON string back in the browser. Keep in mind that the FormatterFunction code is executed in the browser.
        Best regards,
        Martin Pavlov
        Martin Pavlov
        Martin Pavlov answered on Jun 3, 2013 4:27 PM
        Hello Jessica,
        My test showed that the actual serialized value in the browser is only "\n", so you should replace only "\n" and not "\r\n".
        Hope this helps,
        Martin Pavlov
        Jessica J
        Jessica J answered on Jun 3, 2013 4:41 PM
        I don't think that's the problem. I think the problem is with the HTML encoding.
        The line break IS SUCESSFULLY REPLACED with the break tag. The problem is that instead of the break tag being a line break, it's displayed as "<br/>"
        Martin Pavlov
        Martin Pavlov answered on Jun 3, 2013 4:57 PM
        Do you have template configured for the column. If you have then remove it.
        If this doesn't help, can you provide a sample for me to investigate.
        Best regards,
        Martin Pavlov
        Maxime DRIVET
        Maxime DRIVET answered on Jan 14, 2014 12:23 PM
        I have exactly the same problem. My grid displays "<br/>" instead of a real line break.
        And this is due to my RowTemplate: If I remove it, the formatter works.
        Can you help me ?
        Maxime DRIVET.
        Maxime DRIVET
        Maxime DRIVET answered on Jan 14, 2014 3:33 PM
        This is my workaround :
        – First, remove the FormatterFunction for desired column.
        – Add a class in RowTemplate like : "<td class=\"applyMultilineFormater\">${MyColumnValue}</td>"
        – Then, add a delegate to intercept the 'dataRendered' event.
        $(document).delegate("#myMasterGridName", "iggriddatarendered", function (evt, ui) {
        $('.applyMultilineFormater').each(function () {
        $(this).html(MultilineFormater($(this).html()));
        function MultilineFormater(val) {
        And it works !
        Feel free to correct/update my code.
        Thanks.
Jessica J
12 years, 9 months ago
Feb 19, 2026 2:56 PM
