Set page index to start of the page when grid data has changed
Version: Ultrawebgrid11.1
I have a grid whose DataSource is set in IntializeDataSource. I also have multiple dropdowns on the page based on I fetch data from database and set the datasource.
Paging and other grid properties are initialized inside IntializeDataSource itself.
Consider grid has 20 pages of data.
1. Navigate to 20th page.
2. Change the dropdown value.
(code fetches a set of data based on dropdown value and is given to grid's DataSource)
3. Now Grid has only 15 pages of data. But page is still indexed at 20th page which has no data.
(to view the data I have to navigate to first page)
How to make page index set to first page when data in the grid is changed? And also when i filter the grid page will not come back to first page.
Code:
Protected Sub SampleGrid_InitializeDataSource(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.UltraGridEventArgs) Handles
SampleGrid .InitializeDataSource
Dim htmlString As New StringBuilder
' Properties needed to enable LoadOnDemand
SampleGrid.Browser = BrowserLevel.Xml
SampleGrid.DisplayLayout.LoadOnDemand = LoadOnDemand.Xml
'LoadOnDemand configuration options
SampleGrid.DisplayLayout.RowsRange = 100
SampleGrid.DisplayLayout.XmlLoadOnDemandType = XmlLoadOnDemandType.Accumulative
SampleGrid.DisplayLayout.Pager.StyleMode = PagerStyleMode.QuickPages
SampleGrid.DisplayLayout.Pager.AllowCustomPaging = False
SampleGrid.DisplayLayout.Pager.AllowPaging = True
SampleGrid.DisplayLayout.Pager.PageSize = 100
SampleGrid.DisplayLayout.Pager.QuickPages = 5
htmlString.Append("<table cellspacing='0' cellpadding='0' style='width:100%;border:solid 1px Black;'>")
htmlString.Append("<tr>")
htmlString.Append("<td width='25%' align='right'>Viewing page [currentpageindex] of [pagecount] </td>")
htmlString.Append("<td align='center'>")
htmlString.Append("<b>[page:1:First] [prev]</b>")
htmlString.Append(" ")
htmlString.Append("[default]")
htmlString.Append("<b>[next] [page:[pagecount]:Last]</b>")
htmlString.Append("</td>")
htmlString.Append("<td width='25%' align='left' title='Enter page number and press Enter'>")
htmlString.Append("Go to:<input id='PagerGotoPageNumber' size='5' style='vertical-align:text-bottom;height:20px;font-family:verdana;font-size:8pt;padding:0 0 0 0;border:solid 1px black' onkeydown='return gotoPageKeyDown();' type='text' autocomplete='off' />")
htmlString.Append("<button style='height:22px' onclick='gotoPage();'>Go</button>")
htmlString.Append("</tr>")
htmlString.Append("</table>")
SampleGrid.DisplayLayout.Pager.Pattern = htmlString.ToString()
LoadGrid()
End Sub
Private dsData As System.Data.DataSet = Nothing
Public Sub LoadGrid()
Dim totalNumOfRecords As Integer = 0
dsData = Get Data from Database
totalNumOfRecords = dsData.Tables(0).Rows.Count
If totalNumOfRecords > Me.
SampleGrid .DisplayLayout.Pager.PageSize Then
Me.SampleGrid.DisplayLayout.Pager.PageCount = Math.Ceiling(totalNumOfRecords / Me.SampleGrid .DisplayLayout.Pager.PageSize)
End If
SampleGrid.DataSource = dsData.Tables(0)
End Sub
Protected Sub
SampleGrid _InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.LayoutEventArgs) Handles
SampleGrid .InitializeLayout
GatherFilterDataForColumnString(e.Layout.Bands(0).Columns.FromKey("xxx"))
GatherFilterDataForColumnDate(e.Layout.Bands(0).Columns.FromKey("yyy"))
End Sub
