Infragistics Community Forum / Web / Ignite UI for Angular / Opening of Dialog/Popup on click of any column data in Igx_grid
Subham  Karan
Subham Karan asked on Apr 14, 2020 10:06 AM
Hi All,
I have a requirement which includes to open a popup or dialog on click of a particular column in Igx_grid, Any Idea how can we implement this feature using Ignite UI.
An Example for the solution would be very much helpful.
Subham
    Tihomir Tonev
    Tihomir Tonev answered on Mar 30, 2020 8:17 AM
    A way to achieve your goal would be to use the grid's onCellClick event, which will give you information about the row/column you have clicked, and then you can open the dialog programatically.
    onCellClick(event: IGridCellEventArgs) {
        if (event.cell.rowIndex % 2 === 0) {
          this.dialog.open();
    The following code will open a dialog on alternate rows.
    Attached is an example for further reference.
    Tihomir Tonev
      Subham  Karan
      Subham Karan answered on Apr 8, 2020 2:29 PM
      Hi Tonev,
      The requirement for is like:
      on click of a "specific column data", i should open a dialog an not on any other columns click and also the column data which i clicked must be display on the popup, so can you please provide relevant info regarding this change.
      A working stackblitz example would be very much helpful.
      Subham Karan
        Tihomir Tonev
        Tihomir Tonev answered on Apr 9, 2020 1:16 PM
        I understand the requirement, however without specifying which column data, and just "specific column data", it could mean anything.
        I have modified the sample to display a dialog with the column data clicked.
        Please note that when clicking on a cell, the event arguments return this cell, which holds information about row, column, the grid itself, so you can use this information and decide whether this is the specific cell.
        If you need help to retrieve a certain value, please let me know.
        Tihomir Tonev
        RowEditTemplate.zip
        Subham  Karan
        Subham Karan answered on Apr 14, 2020 7:25 AM
        Hi Tonev,
        Thank you for the help, is there a way for highlighting a column which a user can easily identify to click on?
        For ex:if i want only TopSpeed(column) to be clickable, Can we have  custom style to highlight the column as href may be?
        An working live example would be very much helpful.
        Subham
        Tihomir Tonev
        Tihomir Tonev answered on Apr 14, 2020 10:06 AM
        Yes, you can style all cells conditionally in the grid. Here is an example setting the background of Top Speed column to to  be flashing -> link.
        More information about conditional styling can be found in our documentation here.
        Should you have any further questions, please let me know.
        Tihomir Tonev
Subham Karan
6 years, 7 months ago
Feb 16, 2026 9:37 PM
