Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Applying dynamic css class styles for each record
[Infragistics] Duane Hoyt
[Infragistics] Duane Hoyt asked on Mar 14, 2011 3:09 PM
How to create and apply dynamic css classes for each record.
    [Infragistics] Duane Hoyt answered on Mar 14, 2011 3:09 PM
    First you can create a StringBuilder for organizing the list of css classes that you would like to create dynamically:
    StringBuilder cssSylesBuilder = new StringBuilder();
    cssSylesBuilder.Append(".BG1 {background-color: red !important;}");
    cssSylesBuilder.Append(".BG2 {background-color: blue !important;}");
    cssSylesBuilder.Append(".BG3 {background-color: green !important;}");
    Then you can register the css styles to a variable in JavaScript using the RegisterClientScriptBlock:
    Page.ClientScript.RegisterClientScriptBlock(
        this.GetType(),
        "MyCss",
        "var cssStyles = '" + cssSylesBuilder.ToString() + "'",
        true);
    This will register the variable "cssStyles" as a string.
    Then you can handle the WebDataGrid's Initialize client side event and dynamically create a style element so that it can be set to the css text that is stored in "cssStyles":
    function WebDataGrid1_Grid_Initialize(sender, eventArgs)
        ///<summary>
        ///</summary>
        ///<param name="sender" type="Infragistics.Web.UI.ControlMain"></param>
        ///<param name="eventArgs" type="Infragistics.Web.UI.EventArgs"></param>
        var styleElement = document.createElement('style');
        var styleClasses = cssStyles;
        styleElement.setAttribute("type", "text/css");
        styleElement.styleSheet.cssText = styleClasses;
        var headElement = document.getElementsByTagName('head')[0];
        headElement.appendChild(styleElement);
    Finally you can handle the InitializeRow event and apply some logic to certain records. To set the css class for a record in particular you can retrieve a reference to all cells using "e.Row.Items[index]" which contains a GridRecordItem. Within the GridRecordItem reference you can set the CssClass property:
    for (int i = 0; i < e.Row.Items.Count; i++)
        e.Row.Items[i].CssClass = "BG1";
    This will apply the css class "BG1" to this record in particular.
    Sample is attached to the thread for an example.
15 years, 1 month ago
