Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Element is not a known element. This can occur if there is a compilation error in the website or the web.config file is missing
Jack
Jack asked on Nov 25, 2019 7:14 AM
I am converting Infragistics 2010 v2 CLR3.5 to Infragistics 2014 v2 using 4.5 CLR using Visual Studio 2013 Professional Update 4. I am getting following error while building the project. Please reply immediately……….
The below code is in ASPX Design page and I am getting following error at the highlighted location while running the project:……………Reply soon with a fix and example
Error: “Element is not a known element. This can occur if there is a compilation error in the website or the web.config file is missing”
FYI…. in above error I have verified the web.config file and there it is already this tag –  <pages controlRenderingCompatibilityVersion=“4.5“ clientIDMode=“AutoID“/>
<%@ Register TagPrefix="uta1" TagName="finding" Src="~/Controls/finding.ascx" %>
<%@ Register TagPrefix="uta1" TagName="filtering" Src="~/Controls/filtering.ascx" %>
<table id="tblContent" cellspacing="0" cellpadding="0" width="100%" border="0">
    <tr>
     <td>
<uta1:finding
 ID="Find1" runat="server"></uc1:find> // getting this error on "finding" - Element is not a known element. This can occur if there is a compilation error in the website or the web.config file is missing
<uta1:filtering
 ID="Filter1" runat="server"></uc1:filter> //  getting this error on "filtering" - Element is not a known element. This can occur if there is a compilation error in the website or the web.config file is missing
    </td>
   </tr>
    Zdravko Kolev
    Zdravko Kolev answered on May 21, 2015 1:03 PM
    Your web.config file is not correctly formed. The error message is explaining the issue well enough. You can have a look at the following articles for more information:
    http://stackoverflow.com/questions/3550589/element-x-is-not-a-known-element-web-application
    https://msdn.microsoft.com/en-us/library/dd483478.aspx – section "To manually upgrade an application's Web.config file from the .NET Framework 3.5 to the .NET Framework 4"
      Jack
      Jack answered on May 21, 2015 4:42 PM
      Hi,…. I have clearly mentioned my .NET Framework as 4.5 as it has different web.config tags in that………..Please reply if you know this version
        Zdravko Kolev
        Zdravko Kolev answered on May 22, 2015 12:04 PM
        This issue has nothing to do with your .NET Framework version. Your web.config file is not correctly formed. this section pages, shouldn't be there.
        Zdravko Kolev
        Zdravko Kolev answered on May 28, 2015 2:39 PM
        Hello Jack,
        I am just checking, if you require any further assistance on the matter.
        akbar ali
        akbar ali answered on Jan 23, 2019 5:48 PM
        i have same issue plz help me
        Swaroopa Roopa
        Swaroopa Roopa answered on Nov 15, 2019 12:50 AM
        I have the same issue, I simply delete that  file and add a  new webform with same code. It worked out.
        Zdravko Kolev
        Zdravko Kolev answered on Nov 25, 2019 7:14 AM
        Thank you for sharing this with our forum community.
Jack
6 years, 11 months ago
Feb 12, 2026 7:53 AM
