Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / How to Call Validating Event in Button Click Event
ferdin
ferdin asked on Oct 19, 2009 7:05 AM
Hi Everyone
How to fire a Ultratextbox validating event in Ultrabutton Click event. I tried it usually like these following two methods both throws same errors like this
Method 1:
private void uiButton1_Click(object sender, EventArgs e)
uiTextBox_Validating(this, CancelEventArgs.Empty);
Method 2:
uiTextBox_Validating(this, e);
It throws some errors like
Error 2 The best overloaded method match for ‘Task_2_Control_Panel.FrmControlPanel.uiTextbox_Validating(object, System.ComponentModel.CancelEventArgs)’ has some invalid arguments D:\Task 2 Control Panel\Control Panel.cs 1225 13 Task 2 Control Panel
Error 3 Argument ‘2’: cannot convert from ‘System.EventArgs’ to ‘System.ComponentModel.CancelEventArgs’ D:\Task 2 Control Panel\Control Panel.cs 1225 44 Task 2 Control Panel
Could anyone help me to sort this issue.
Thanks in advance
Ferdin
    Brian Fallon
    Brian Fallon answered on Nov 17, 2008 2:33 PM
    The Form class exposes a method, 'ValidateChildren', which triggers the Validating event for each child of the form. If you want to call the event handler directly, you should not use CancelEventArgs.Empty, but rather a new instance of CancelEventArgs, because the static Empty property is inherited from the System.EventArgs class, and you need a strongly-typed CancelEventArgs instance to call the event handler directly. Also, the value of the 'sender' parameter should probably be uiTextBox, not this, in case the handler logic is expecting the sender to be of a specific type.
      ferdin
      ferdin answered on Nov 18, 2008 3:34 AM
      Thanks Brain Fallon,
      I dont understand it clearly. Could you more specific with this or could you please code that for me.
    Rhea
    Rhea answered on Oct 19, 2009 7:05 AM
    I too had the same problem when I tried to fire a validating event within a ButtonClick event.I went through the reply answer to ur post.But answer is not clear to me as well[quote user="ferdin"]
    Hi Everyone
    Method 1:
    Method 2:
    Error 2 The best overloaded method match for 'Task_2_Control_Panel.FrmControlPanel.uiTextbox_Validating(object, System.ComponentModel.CancelEventArgs)' has some invalid arguments D:\Task 2 Control Panel\Control Panel.cs 1225 13 Task 2 Control Panel
    Error 3 Argument '2': cannot convert from 'System.EventArgs' to 'System.ComponentModel.CancelEventArgs' D:\Task 2 Control Panel\Control Panel.cs 1225 44 Task 2 Control Panel
    Thanks in advance
    Ferdin
    [/quote]….
ferdin
17 years, 1 month ago
Feb 23, 2026 4:54 PM
