Change the WebDataGrid cell value
achraf gharbi
achraf gharbi asked on Jun 3, 2019 6:43 AM
hi ,
iam using autogenerated columns in the webdatagrid and i want to change  any cell value without using an  UnboundField ,
is this possible ?
thank you.
    Nadia Robakova
    Nadia Robakova answered on May 31, 2019 6:59 AM
    You can change the cell value in the InitializeRow event. For example:
            e.Row.Items[1].Text = "Updated Text " + e.Row.Index;
    You can look at this forum post:
    https://www.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/42999/how-to-change-the-value-of-a-column-in-the-initializerow-event-of-the-webdatagrid
      achraf gharbi
      achraf gharbi answered on May 31, 2019 10:18 AM
      hi,
      i always keep receving  A cell value can only be set for cells that are part of an UnboundField Error.
      i just want remove or hide the value of a cell when i enable the EditCore .
      thank you.
        Nadia Robakova
        Nadia Robakova answered on Jun 3, 2019 6:43 AM
        Can you send us a small sample whit the behavior that you want?
        When you want to change the cell value? When you open a cell in edit mode or when the grid is loaded?
        There should not be difference when using UnboundField or BoundField.
achraf gharbi
7 years, 5 months ago
Jun 3, 2019 6:43 AM
Jun 3, 2019 6:43 AM
