Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Convert grid cell display values ‘true/false’ into ‘Yes/No’
Brian
Brian asked on Dec 8, 2011 3:17 PM
I’d like to change what the user sees in the grid. Let’s say I have a boolean column that is showing ‘true’ or ‘false’ and I’d like to show ‘Yes’ or ‘No’ instead.
I seem to be able to accomplish this somewhat by placing some code in the InitializeRow event.
Like…
GridRecordItem activated = e.Row.Items.FindItemByKey(“Activated”);
if (activated != null)
if ((bool)activated.Value == false)
activated.Text = “No”;
if ((bool)activated.Value == true)
activated.Text = “Yes”;
This seems to work, however if I edit a different value in the row and move to another row the formatting on the ‘Yes/No’ reverts back to ‘true/false’.
So, it seems that after a row has been updated I need to reapply the formatting.
Where is the appropriate place to format the display value of a cell?
Brian.
    Alex E
    Alex E answered on Dec 8, 2011 2:57 PM
    Hello Brian,
    Look at the following forum thread and let me know if this is the functionality that you require – http://community.infragistics.com/forums/p/57603/293756.aspx#293756
      Brian
      Brian answered on Dec 8, 2011 3:17 PM
      Well, not exactly what I was looking for. However, I did stumble across a solution.
      Each column has a FormatFieldMethod. So, for the true/false to Yes/No conversion, you can define a conversion method like…
      private
      string FormatTrueFalseToYesNo(ControlDataField field, object
      value)
      if (value is Boolean)
      Boolean trueFalse = (Boolean)value;
      if (trueFalse == true)
      return "Yes";
      if (trueFalse == false)
      return "No";
      return "Error";
      Then in the Initialize row event I do…
      GridRecordItem activated = e.Row.Items.FindItemByKey("Activated");
      if
      (activated != null &&
      activated.Column.FormatFieldMethod == null)
      activated.Column.FormatFieldMethod = new FormatRecordItemValue(FormatTrueFalseToYesNo);
      Now all of the true / false fields say Yes or No and this stays updated when I edit other cells in a row and move to other rows.
      This is not a solution if you want to be able to type in Yes or No, this is only a solution to display a different text in a cell.
Brian
14 years, 11 months ago
Dec 8, 2011 3:17 PM
Feb 12, 2026 9:48 AM
