Custom format string per cell
New DiscussionDear Infragistics support,
I’m trying to fulfil the following requirements for a grid with all bound columns:
- Edit a cell value in a dedicated column with the fixed input mask {double:-8.6}
- Display the cell value in the dedicated column with a custom format string (percentage, integer value, numeric with variable precision)
- The format string is variable per cell, i.e. not equal for all cells of the deciated column
The expected behaviour is, that the raw value is displyed in edit mode as defined in input mask. Whenever the edit mode terminates, the formatting applies to the dedicated cell.
The data type of the affected bound column in my example is Nullable<decimal>. My attempts to realize the requirements have failed so far using the following approaches:
- Assign the UltraGridCell.Editor an EditorWithMask instance with set MaskInput and FormatString property values in InitializeRow event of the grid.
The expected formatting didn’t apply after exiting the edit mode. - Assign the UltraGridCell.EditorComponent an UltraNumericEditor instance with set MaskInput and FormatString property values in InitializeRow event of the grid.
Only the input mask seems to apply, but not the format string.
I’m aware to set UseEditorMaskSettings = true for the dedicated column.
What do I miss or is there a different, more promising approach? By reading other posts, I stumbled over the usage of a custom data filter to handle the custom formatting.
I kindly expect your response.
Sign In
to post a reply
2 Created On
Nov 16, 2017 Last Post
8 years, 12 months ago
