Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Fix “DataKeyField Is Invalid” Error in Grid Binding
Marco
Marco asked on Mar 30, 2012 11:16 AM
I’m doing some tests on WebDataGrid in ASP.Net 4.0, and I have this error:
[InvalidOperationException: DataKeyField is invalid]
Infragistics.Web.UI.Framework.Data.DataSourceAdapter.Select(DataSourceSelectArguments arguments) +651
Infragistics.Web.UI.Framework.Data.DataSourceObjectView.ExecuteSelect(DataSourceSelectArguments arguments) +73
System.Web.UI.DataSourceView.Select(DataSourceSelectArguments arguments, DataSourceViewSelectCallback callback) +21
System.Web.UI.WebControls.DataBoundControl.PerformSelect() +143
System.Web.UI.WebControls.BaseDataBoundControl.DataBind() +74
Infragistics.Web.UI.GridControls.WebDataGrid.DataBind() +974
Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.EnsureDataBound() +73
Infragistics.Web.UI.GridControls.WebDataGrid.EnsureDataBound() +186
Infragistics.Web.UI.GridControls.WebDataGrid.CreateChildControls() +75
System.Web.UI.Control.EnsureChildControls() +102
Infragistics.Web.UI.GridControls.WebDataGrid.EnsureChildControls() +129
System.Web.UI.Control.PreRenderRecursiveInternal() +42
System.Web.UI.Control.PreRenderRecursiveInternal() +175
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2496
My WebDataGrid in .aspx page is defined in this way:
<ig:WebDataGrid runat=”server” ID=”grdOrders” Height=”400px” Width=”600px” EnableViewState=”true”>
<Behaviors>
<ig:Sorting Enabled=”true”></ig:Sorting>
<ig:Filtering Enabled=”true”></ig:Filtering>
<ig:ColumnMoving Enabled=”true”></ig:ColumnMoving>
<ig:EditingCore Enabled=”true”>
<Behaviors>
<ig:CellEditing Enabled=”true”></ig:CellEditing>
</Behaviors>
</ig:EditingCore>
</Behaviors>
</ig:WebDataGrid>
While in the code behind I have only this code:
Dim dtOrders As DataTable
Dim sSql As String = “SELECT OrderYear,OrderType,OrderNumber,CustomerCode FROM Orders WHERE OrderYear=2012”
LoadTable(DBConnection, dtOrders, “Ordini”, sSql, True, New String() {“OrderYear”, “OrderType”, “OrderNumber”})
grdOrders.DataSource = dtOrders
grdOrders.DataKeyFields = “OrderYear,OrderType,OrderNumber”
LoadTable is a function which executes the SQL script, loads data into the DataTable dtOrders and sets the Primary Key with the fields “OrderYear”, “OrderType”, and “OrderNumber”
The problem is that if I comment the “grdOrders.DataKeyFields…” row, everything works well, but I’m not able to modify any cell in the html page (if I try to do that, at first postback an error saying that I must set DataKeyField is triggered). Instead, if I uncomment that line, the page doesn’t show up and the “DataKeyField is invalid” error is triggered.
How can I solve this? Thanks for any help!
    Marco
    Marco answered on Mar 29, 2012 4:21 PM
    Add-on: I'm using NetAdvantage ASP.NET 2011 Vol. 2 on Visual Studio 2010 and Framework 4.0.
      [Infragistics] Nikolay
      [Infragistics] Nikolay answered on Mar 30, 2012 9:57 AM
      Hi elvandar,
      Please refer to the attached sample, in which I used DataTable with composite primary key and WebDataGrid with enabled row updating. I would also suggest that you check the following threads which you might find helpful – http://blogs.infragistics.com/forums/p/41108/230234.aspx, http://blogs.infragistics.com/forums/p/58655/298258.aspx.
      Please let me know if this helps.
        Marco
        Marco answered on Mar 30, 2012 10:57 AM
        Thanks for your feedback.
        I solved the problem a minute ago. It was the, despite capital letters in the query (like "OrderYear") columns were loaded with all lower letters.
        After changing
        grdOrders.DataKeyFields = "OrderYear,OrderType,OrderNumber"
        with
        grdOrders.DataKeyFields = "orderyear,ordertype,ordernumber"
        everything started working.
        [Infragistics] Nikolay answered on Mar 30, 2012 11:16 AM
        Hello elvandar,
        I'm glad you solved this.
        If you have any other questions, do not hesitate to ask.
Marco
14 years, 8 months ago
Feb 23, 2026 8:40 AM
