Drop Down Default Option
Vincent Novak
Vincent Novak asked on Dec 6, 2025 5:07 PM
I’m having trouble getting the default option for a drop down item to work when running a prototype. In design mode, the drop down is collapsed, and I’ve set a hint for the drop down. But when I run the prototype it is automatically selecting the first option.
The interaction I’m attempting to mockup is a series of drop down menus, so I’ve set the state to change when the user makes a selection. I want to leave the drop down blank until a user picks an option.
I believe I’ve used this same approach in earlier versions of Indigo and it worked, has anyone else seen this since updating recently?
    George Abraham
    George Abraham answered on May 4, 2018 9:45 PM
    Hi, there.
    The dropdown remembers the value you had last selected before you collapsed the dropdown. If you want to show the dropdown as blank, make sure there is no hint text and collapse the drop down on the design surface. Let us know whether we understood your question correctly.
      Vincent Novak
      Vincent Novak answered on May 7, 2018 1:50 PM
      Thanks George, that did address my question. I think my issue was that I had the dropdown in a screenpart, and the screenpart had the first item in the dropdown selected. I had to go back into the source screenpart and change the template to select the hint to resolve the issue.
    Henry Jame
    Henry Jame answered on Mar 16, 2026 3:08 AM
    This usually happens because the dropdown component automatically selects the first item when the prototype runs. In Adobe XD (formerly Project Indigo), the hint text is only a visual placeholder in design mode and does not always behave like a true “empty” default value during prototyping.
    A common workaround is to add a blank or “Select an option…” item as the first option in the dropdown list. This keeps the field looking empty when the prototype starts and lets the user make a selection afterward.
    If you are using component states for the dropdown interaction, make sure the default state is the one that shows the placeholder or empty value before any selection is made.
    yosipa Reil
    yosipa Reil answered on Oct 19, 2026 5:15 PM
    This sounds like the dropdown might be treating the first option as its default value instead of showing the hint as a placeholder. I’d check whether the component has an initial value or selected state set, and whether the hint is configured separately from the options. If it still selects the first option automatically, it could be a change in the newer version of Indigo. You can also test with a simple dropdown without any interactions to see whether the behavior persists.
    To check how audio is positioned and separated during playback, you can also try this Soundstage test.
    Oliver rr
    Oliver rr answered on Oct 21, 2026 3:41 PM
    This sounds like a frustrating issue, especially when trying to create a prototype that accurately reflects how users interact with dropdown menus. Keeping the dropdown blank until a selection is made is important for testing the intended user experience. Reviewing the interaction settings and the event Schedule may help identify whether the updated version has changed how default values are handled.
Vincent Novak
3 weeks, 4 days ago
Dec 6, 2025 5:07 PM
Feb 24, 2026 10:19 AM
