Hi Rob,
Thanks for replying. Here it is:
<?xml version="1.0"?>
Note: As an alternative to hand editing this file you can use the
web admin tool to configure settings for your application. Use
the Website->Asp.Net Configuration option in Visual Studio.
A full list of settings and comments can be found in
machine.config.comments usually located in
\Windows\Microsoft.Net\Framework\v2.x\Config
<configuration>
<configSections>
<section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089"/>
<section name="ActiveReports7" type="GrapeCity.ActiveReports.Web.ActiveReportsSettingsSection"/>
</configSections>
<infragistics.web enableAppStyling="true" styleSetName="Appletini" styleSetPath="~/ig_res/"/>
<appSettings>
<add key="ChartImageHandler" value="storage=file;timeout=20;dir=c:\TempImageFiles\;"/>
<add key="DataDynamicsARLic" value="John Rothwell,Mott MacDonald,DD-APN-30-C002284,74EOF444SSHFJHUF7M4H"/>
<add key="ApplicationRoot" value="http://www.sds-online.biz/bordello/"/>
<add key="ProgramVersion" value="1.1.001"/>
<add key="ProgramReleaseDate" value="23rd October 2012"/>
<add key="CookieEncryptionKey" value="{02CB9382-64DE-493D-8C59-19DC15D7FC30}"/>
<add key="URLEncryptionKey" value="{02CB9382-64DE-493D-8C59-19DC15D7FC30}"/>
</appSettings>
<connectionStrings>
<add name="SDS" connectionString="Data Source=.\SDS2012;Initial Catalog=xxxx;Integrated Security=True;" providerName="System.Data.SqlClient"/>
<add name="OLE" connectionString="Provider=SQLOLEDB.1;Data Source=.\SQL2012;Initial Catalog=BRL7;Persist Security Info=True;User ID=xxxx;Password=xxxx;"/>
<add name="LNQ" connectionString="Data Source=.\SQL2012;Initial Catalog=xxxx;Integrated Security=True;" providerName="System.Data.SqlClient"/>
</connectionStrings>
<system.web>
<globalization culture="en-GB" uiCulture="en-GB" fileEncoding="utf-8"/>
Set compilation debug="true" to insert debugging
symbols into the compiled page. Because this
affects performance, set this value to true only
during development.
<compilation debug="true" targetFramework="4.0">
<assemblies>
<add assembly="System.Web.Extensions.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
<add assembly="Microsoft.ReportViewer.Common, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/>
<add assembly="Microsoft.ReportViewer.WebForms, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/>
<add assembly="System.Web.DataVisualization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="GrapeCity.ActiveAnalysis.Extensions, Version=2.1.827.0, Culture=neutral, PublicKeyToken=D557F2F30A260DA2"/>
<add assembly="GrapeCity.ActiveAnalysis.Web, Version=2.1.827.0, Culture=neutral, PublicKeyToken=D557F2F30A260DA2"/>
<add assembly="GrapeCity.ActiveReports.Web.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Document.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Pdf.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Html.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Xml.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Xaml.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Excel.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Word.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Image.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Export.Rdf.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Document.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="GrapeCity.ActiveReports.Extensibility.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=CC4967777C49A3FF"/>
<add assembly="Infragistics4.Web.v12.2, Version=12.2.20122.2014, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics4.WebUI.Documents.Reports.v12.2, Version=12.2.20122.2014, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics4.WebUI.Documents.Excel.v12.2, Version=12.2.20122.2014, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics4.WebUI.Documents.Word.v12.2, Version=12.2.20122.2014, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
<add assembly="Infragistics4.WebUI.Documents.IO.v12.2, Version=12.2.20122.2014, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
</assemblies>
<buildProviders>
<add extension=".rdlc" type="Microsoft.Reporting.RdlBuildProvider, Microsoft.ReportViewer.WebForms, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"/>
</buildProviders>
</compilation>
The <authentication> section enables configuration
of the security authentication mode used by
ASP.NET to identify an incoming user.
<authentication mode="Windows"/>
<siteMap defaultProvider="XmlSiteMapProvider" enabled="true">
<providers>
<add name="XmlSiteMapProvider" type="System.Web.XmlSiteMapProvider" siteMapFile="Web.sitemap" securityTrimmingEnabled="true"/>
</providers>
</siteMap>
The <customErrors> section enables configuration
of what to do if/when an unhandled error occurs
during the execution of a request. Specifically,
it enables developers to configure html error pages
to be displayed in place of a error stack trace.
<customErrors mode="RemoteOnly" defaultRedirect="GenericErrorPage.htm">
<error statusCode="403" redirect="NoAccess.htm" />
<error statusCode="404" redirect="FileNotFound.htm" />
</customErrors>
<pages theme="SDS" controlRenderingCompatibilityVersion="3.5" clientIDMode="AutoID">
<controls>
<!–Data Aquarium Framework and AjaxControlToolkit references–>
<add tagPrefix="act" namespace="AjaxControlToolkit" assembly="AjaxControlToolkit"/>
<add tagPrefix="act" namespace="AjaxControlToolkit.HTMLEditor" assembly="AjaxControlToolkit"/>
<add tagPrefix="aquarium" namespace="SDS.Web" assembly="SDS"/>
<add tagPrefix="asp" namespace="System.Web.UI.DataVisualization.Charting" assembly="System.Web.DataVisualization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
</controls>
</pages>
<httpHandlers>
<add path="*.xml" verb="*" type="System.Web.HttpForbiddenHandler" />
<add path="Reserved.ReportViewerWebControl.axd" verb="*" type="Microsoft.Reporting.WebForms.HttpHandler, Microsoft.ReportViewer.WebForms, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"
validate="false" />
<add path="Blob.ashx" verb="*" type="SDS.Handlers.Blob" validate="false" />
<add path="Export.ashx" verb="*" type="SDS.Handlers.Export" validate="false" />
<add path="Import.ashx" verb="*" type="SDS.Handlers.Import" validate="false" />
<add path="Details.aspx" verb="*" type="SDS.Handlers.Details"
validate="false" />
<add path="Report.ashx" verb="*" type="SDS.Handlers.Report" validate="false" />
<add path="ControlHost.aspx" verb="*" type="SDS.Web.ControlHost"
validate="false" />
<add path="ChartHost.aspx" verb="*" type="SDS.Web.ChartHost"
validate="false" />
<add path="ChartImg.axd" verb="GET,HEAD,POST" type="System.Web.UI.DataVisualization.Charting.ChartHttpHandler, System.Web.DataVisualization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"
validate="false" />
<add path="*.rpx" verb="*" type="GrapeCity.ActiveReports.Web.Handlers.RpxHandler, GrapeCity.ActiveReports.Web.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff" />
<add path="*.rdlx, *.rdl" verb="*" type="GrapeCity.ActiveReports.Web.Handlers.RdlxHandler, GrapeCity.ActiveReports.Web.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff" />
<add path="*.ar7" verb="*" type="GrapeCity.ActiveReports.Web.Handlers.ReportBinariesStreamer, GrapeCity.ActiveReports.Web.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff" />
<add path="*.ar7Web" verb="*" type="GrapeCity.ActiveReports.Web.Handlers.WebCacheAccessHandler, GrapeCity.ActiveReports.Web.v7, Version=7.0.5341.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff" />
<add path="*.igrResource" verb="*" type="Infragistics.Reports.Server.ResourcesHandler, InfragisticsWPF4.Reports.Server.v12.2, Version=12.2.20122.1014, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
validate="false" />
</httpHandlers>
<httpModules>
<add name="ReportProcessorServiceModule" type="Infragistics.Reports.Server.ReportProcessorServiceModule, InfragisticsWPF4.Reports.Server.v12.2, Version=12.2.20122.1014, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
</httpModules>
<webServices>
<protocols>
<remove name="Documentation"/>
</protocols>
</webServices>
</system.web>
The system.webServer section is required for running ASP.NET AJAX under Internet
Information Services 7.x. It is not necessary for previous version of IIS.
<system.webServer>
<validation validateIntegratedModeConfiguration="false"/>
<modules runAllManagedModulesForAllRequests="true"/>
<handlers>
<add name="All_XML" verb="*" path="*.xml" type="System.Web.HttpForbiddenHandler" resourceType="Unspecified"/>
<add name="Reserved_ReportViewerWebControl_axd" path="Reserved.ReportViewerWebControl.axd" verb="*" type="Microsoft.Reporting.WebForms.HttpHandler, Microsoft.ReportViewer.WebForms, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" resourceType="Unspecified"/>
<!–Data Aquarium Framework handlers–>
<add name="Blob_ashx" verb="*" path="Blob.ashx" type="SDS.Handlers.Blob" resourceType="Unspecified"/>
<add name="Export_ashx" verb="*" path="Export.ashx" type="SDS.Handlers.Export" resourceType="Unspecified"/>
<add name="Import_ashx" verb="*" path="Import.ashx" type="SDS.Handlers.Import" resourceType="Unspecified"/>
<add name="Details_aspx" verb="*" path="Details.aspx" type="SDS.Handlers.Details" resourceType="Unspecified"/>
<add name="Report_ashx" verb="*" path="Report.ashx" type="SDS.Handlers.Report" resourceType="Unspecified"/>
<add name="ControlHost_ashx" verb="*" path="ControlHost.aspx" type="SDS.Web.ControlHost" resourceType="Unspecified"/>
<add name="ChartHost_ashx" verb="*" path="ChartHost.aspx" type="SDS.Web.ChartHost" resourceType="Unspecified"/>
<remove name="ChartImageHandler"/>
<add name="ChartImageHandler" preCondition="integratedMode" verb="GET,HEAD,POST" path="ChartImg.axd" type="System.Web.UI.DataVisualization.Charting.ChartHttpHandler, System.Web.DataVisualization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
<remove name="AR7"/>
<remove name="AR7Rdl"/>
<remove name="AR7Rdlx"/>
<remove name="AR7Rpx"/>
<remove name="AR7Web"/>
<add name="AR7" path="*.ar7" verb="*" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersion4.0,bitness64"/>
<add name="AR7Rdl" path="*.rdl" verb="*" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersion4.0,bitness64"/>
<add name="AR7Rdlx" path="*.rdlx" verb="*" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersion4.0,bitness64"/>
<add name="AR7Rpx" path="*.rpx" verb="*" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersion4.0,bitness64"/>
<add name="AR7Web" path="*.ar7Web" verb="*" modules="IsapiModule" scriptProcessor="%windir%\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll" preCondition="classicMode,runtimeVersion4.0,bitness64"/>
</handlers>
</system.webServer>
<system.web.extensions>
<scripting>
<webServices>
<jsonSerialization maxJsonLength="524288"/>
</webServices>
</scripting>
</system.web.extensions>
<system.serviceModel>
<behaviors>
<endpointBehaviors>
<behavior name="SilverlightFaultBehavior">
<silverlightFaults />
</behavior>
<behavior name="JsonFaultBehavior">
<enableWebScript />
<jsonFaults />
</behavior>
</endpointBehaviors>
<serviceBehaviors>
<behavior name="ReportProcessorServiceBehavior">
<serviceMetadata httpGetEnabled="true" />
<serviceDebug includeExceptionDetailInFaults="false" />
</behavior>
</serviceBehaviors>
</behaviors>
<bindings>
<customBinding>
<binding name="binaryHttpBinding">
<binaryMessageEncoding />
<httpTransport />
</binding>
</customBinding>
</bindings>
<extensions>
<behaviorExtensions>
<add name="silverlightFaults" type="Infragistics.Reports.Server.SilverlightFaultBehavior, InfragisticsWPF4.Reports.Server.v12.2, Version=12.2.20122.1014, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
<add name="jsonFaults" type="Infragistics.Reports.Server.JsonErrorWebHttpBehaviorElement, InfragisticsWPF4.Reports.Server.v12.2, Version=12.2.20122.1014, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" />
</behaviorExtensions>
</extensions>
<serviceHostingEnvironment aspNetCompatibilityEnabled="true" />
<services>
<service behaviorConfiguration="ReportProcessorServiceBehavior"
name="Infragistics.Reports.Server.ReportProcessorService">
<endpoint address="soapAddress" behaviorConfiguration="SilverlightFaultBehavior"
binding="customBinding" bindingConfiguration="binaryHttpBinding"
contract="Infragistics.Reports.Server.IReportProcessorService">
<identity>
<dns value="localhost" />
</identity>
</endpoint>
<endpoint address="ajaxAddress" behaviorConfiguration="JsonFaultBehavior"
binding="webHttpBinding" contract="Infragistics.Reports.Server.IReportProcessorService" />
<endpoint address="mex" binding="mexHttpBinding" contract="IMetadataExchange" />
</service>
</services>
</system.serviceModel>
</configuration>
I'm attempting to migrate from ActiveReports7 which is a nightmare to configure with regard to the http handlers. Hopefully, once I have the IG reporting working ok I can get rid of a lot of crud from this file.
Kind regards,
Paul
