Infragistics Community Forum / Web / Ignite UI for jQuery / iggrid fixed header not aligned with row data
Smitesh Shah
Smitesh Shah asked on Nov 25, 2025 10:20 AM
I am setting height of iggrid to set fixed header with vertical scrolling, it is fixed the header, but its not aligned with row data, please refer to this snap.
Below is the code:
$(“#tblCheckInQueList”).igGrid({
primaryKey: “templateID”,
width: ‘100%’,
height: ‘170px’,
autofitLastColumn: false,
autoGenerateColumns: false,
renderCheckboxes: true,
dataSource: data,
showHeader: true,
multiSelection: {
enabled: true
columns: [
{ headerText: “AppTypeMapID”, headerCssClass: “”, key: “appTypeMapID”, dataType: “number”, columnCssClass: “”, hidden: true },
{ headerText: “TemplateID”, headerCssClass: “”, key: “templateID”, dataType: “number”, columnCssClass: “”, hidden: true },
{ headerText: “Select”, headerCssClass: “”, key: “select”, dataType: “bool”, columnCssClass: “”, hidden: true },
{ headerText: “Questionnaire(s)”, headerCssClass: “”, key: “questTemplate”, dataType: “string”, columnCssClass: “smd-font-color” },
{ headerText: “Portal”, key: “portal”, dataType: “boolean”, hidden: true },
headerText: “Portal”, key: “portal1”, dataType: “boolean”, unbound: true, columnCssClass: “text-left”,
formula: function displayStatus(data, grid) {
var ActiveStatus = null;
if (data[“portal”] == true) {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkPortalQI_” + data[“templateID”] + “‘ checked=’checked’ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
else {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkPortalQI_” + data[“templateID”] + “‘ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
return ActiveStatus;
{ headerText: “Clipboard”, key: “clipboard”, dataType: “boolean”, hidden: true },
headerText: “Clipboard”, key: “clipboard1”, dataType: “boolean”, unbound: true, columnCssClass: “text-left”,
if (data[“clipboard”] == true) {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkClipboardQI_” + data[“templateID”] + “‘ checked=’checked’ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
else {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkClipboardQI_” + data[“templateID”] + “‘ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
{ headerText: “Both”, key: “both”, dataType: “boolean”, hidden: true },
headerText: “Both”, key: “both1”, dataType: “boolean”, unbound: true, columnCssClass: “text-left”,
if (data[“both”] == true) {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkBothQI_” + data[“templateID”] + “‘ checked=’checked’ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
else {
ActiveStatus = “<label class=’custom-control custom-checkbox pmd-checkbox smd-margin-bottom-none’><input type=’checkbox’ name=’CheckInQuest_” + data[“templateID”] + “‘ class=’custom-control-input’ onclick=’activeChange(this)’ id=’chkBothQI_” + data[“templateID”] + “‘ /><span class=’custom-control-label pmd-checkbox-ripple-effect’></span></label>”;
// Grid Settings
features: [
enableCheckBoxes: true,
enableRowNumbering: false,
checkBoxStateChanging: function (evt, ui) {
isFiredFromCheckboxCIQ = true;
var grid = $(“#tblCheckInQueList”).data(“igGrid”);
if (ui.newState.toLowerCase() == ‘off’) {
grid.dataSource.updateRow(parseInt(ui.rowKey), { portal: false, clipboard: false, both: false }, true);
$(ui.row[0]).find(“input[id^=’chkPortalQI’]”).prop(‘checked’, false);
$(ui.row[0]).find(“input[id^=’chkClipboardQI’]”).prop(‘checked’, false);
$(ui.row[0]).find(“input[id^=’chkBothQI’]”).prop(‘checked’, false);
else {
grid.dataSource.updateRow(parseInt(ui.rowKey), { both: true }, true);
$(ui.row[0]).find(“input[id^=’chkBothQI’]”).prop(‘checked’, true);
mode: ‘row’,
persist: true,
multipleSelection: true,
activation: true,
rowSelectionChanging: function (evt, ui) {
schApptTypeIsChangesOnKeyup = true;
if (isFiredFromCheckboxCIQ) {
isFiredFromCheckboxCIQ = false;
else {
return false;
enableVerticalRendering: false,
type: “local”,
columnSettings: [
columnKey: “questTemplate”,
allowSorting: false,
columnKey: “portal1”,
columnKey: “clipboard1”,
columnKey: “both1”,
Please help to fix this issue.
    Deyan Kamburov
    Deyan Kamburov answered on Nov 9, 2021 8:37 PM
    It could be bootstrap or some custom styles related to the sample
    I tried it in the following fiddle. Please check it out. The headers are aligned as expected. Can you modify it and send it back with the misaligned headers?
    Ivy Cordes
    Ivy Cordes answered on May 12, 2026 10:32 AM
    This misalignment usually happens because the grid’s fixed header doesn’t account for custom HTML in unbound columns. Try setting explicit column widths or enabling fixedHeaders: true with consistent CSS for both header and body cells—ensuring the checkbox markup doesn’t alter cell sizing. This keeps the header aligned with row data during vertical scrolling.
    olivia olivia
    olivia olivia answered on Oct 30, 2026 9:05 AM
    The column misalignment issue occurs when setting a fixed height in igGrid because the grid splits the header and body into separate HTML tables to enable vertical scrolling. Without explicit column dimensions, the browser calculates widths for the header and body cells independently. To resolve this, you need to set explicit width properties on all visible columns (e.g., width: “40%” or fixed pixel values) and set autofitLastColumn: true. Additionally, ensure that custom CSS (such as padding or margins from Bootstrap or custom classes) isn’t overriding standard th and td cell sizing.  txtag login
Smitesh Shah
1 week, 4 days ago
Feb 12, 2026 4:04 PM
