Infragistics Community Forum / Web / Ignite UI for jQuery / How to insert data to multiple table in same time
ahmed salah
ahmed salah asked on Aug 22, 2016 8:39 AM
I need to make multiple insert to multiple table have relation with each other
what i need actually when user click submit
Save the following data
Name,Email,Salary,DistrictId in table Employee
EmployeeId,CourseId in table EmployeeCourse
EmployeeId,LanaguageId,LevelId in table EmployeeLangage
what i write in create function in empcourse controller
my custom model as following
public class Customemployee
public string Name { get; set; }
public string Salary { get; set; }
public string Email { get; set; }
public int DistrictId { get; set; }
public List<Empcourse> Courses { get; set; }
public List<Emplangauge> Langs { get; set; }
public class Empcourse
public int Id { get; set; }
public int EmployeeId { get; set; }
public int CourseId { get; set; }
public class Emplangauge
public int LevelId { get; set; }
public int LanguageId { get; set; }
my controller empcourse is
public class empcourseController : Controller
mycourseEntities db = new mycourseEntities();
// GET: empcourse
public ActionResult Index()
return View();
public ActionResult Create()
ViewBag.CountryId = new SelectList(db.Countries.ToList(), "Id", "CountryName");
ViewBag.LanaguageId = new SelectList(db.Languages.ToList(), "Id", "LnaguageName");
ViewBag.LevelId = new SelectList(db.Levels.ToList(), "Id", "LevelName");
ViewBag.CourseId = new SelectList(db.Courses.ToList(), "Id", "CourseName");
return View();
[HttpPost]
public ActionResult Create(Customemployee cemp)
return View();
public JsonResult getcitybyid(int id)
db.Configuration.ProxyCreationEnabled = false;
return Json(db.Cities.Where(a => a.CountryId == id), JsonRequestBehavior.AllowGet);
public JsonResult getdistrictbyid(int id)
return Json(db.Destricts.Where(a => a.CityId == id), JsonRequestBehavior.AllowGet);
my Create view is
<html>
<head>
<meta name="viewport" content="width=device-width" />
<title>Create</title>
<script src="~/scripts/jquery-1.10.2.js"></script>
<script>
$(function () {
$("#CountryId").change(function () {
$("#citylist").empty();
// alert("error");
var x = $(this).val();
$.ajax({
url: "/empcourse/getcitybyid",
data: { id: x },
success:function(res)
$.each(res, function (i, e) {
$("#citylist").append("<option value='" + e.Id + "'>" + e.CityName + "<option>")
$("#citylist").change(function () {
$("#districtlist").empty();
// alert("error");
var y = $(this).val();
$.ajax({
url: "/empcourse/getdistrictbyid",
data: { id: y },
success: function (res) {
$("#districtlist").append("<option value='" + e.Id + "'>" + e.DistrictName + "<option>")
$("#CourseId").change(function () {
var index = 0;
var id = $(this).val();
var txt = $("#CourseId option:selected").text();
$("#tb").append("<tr><td><input type = 'hidden' name='Courses[" + index + "].CourseId' value='" + id + "'/></td><td>" + txt + "</td><td><input type='button' value='remove' class='r'</td></tr>")
index++;
$("#tb").on("click", ".r", function () {
$(this).parent().parent().hide();
$(this).parent().prev().prev().find("input").val("0");
$("#LanaguageId").change(function () {
var index1 = 0;
var id1 = $(this).val();
var txt1 = $("#LanaguageId option:selected").text();
$("#tb1").append("<tr><td><input type = 'hidden' name='Langs[" + index1 + "].LanguageId' value='" + id1 + "'/></td><td>" + txt1 + "</td><td><input type='button' value='remove' class='s'</td></tr>")
index1++;
$("#tb1").on("click", ".s", function () {
$("#LevelId").change(function () {
var index2 = 0;
var id2 = $(this).val();
var txt2 = $("#LevelId option:selected").text();
$("#tb2").append("<tr><td><input type = 'hidden' name='Langs[" + index2 + "].LevelId' value='" + id2 + "'/></td><td>" + txt2 + "</td><td><input type='button' value='remove' class='y'</td></tr>")
index2++;
$("#tb2").on("click", ".y", function () {
</script>
</head>
<body>
<div>
@using (Html.BeginForm())
<div>
<br />
Salary:@Html.TextBoxFor(a => a.Salary)
<br />
Email:@Html.TextBoxFor(a => a.Email)
<br />
Country:@Html.DropDownList("CountryId")
<br />
City:<select id="citylist" name="CityId"></select>
<br />
District:<select id="districtlist" name="DistrictId"></select>
<br />
Courses:@Html.DropDownList("CourseId")
<br />
<br />
<table id="tb"></table>
<br />
<br />
Language:@Html.DropDownList("LanaguageId")
<br />
<br />
<table id="tb1"></table>
<br />
<br />
Level:@Html.DropDownList("LevelId")
<br />
<br />
<table id="tb2"></table>
<br />
<input type="submit" />
</div>
</div>
</body>
</html>
my interface and Relation diagram is in this link
    Tihomir Iliev
    Tihomir Iliev answered on Aug 22, 2016 8:39 AM
    Hello Ahmed,
    Thank you for contacting us.
    Do you use Infragistics controls?
    Can you send a working sample so I could further investigate? You could archive it in a zip.
ahmed salah
10 years, 2 months ago
