Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / I want to change the color of the graph by use Stylesheet.css
sulada sudjai
sulada sudjai asked on Jan 28, 2016 2:32 PM
I want to change the color of the graph  by use Stylesheet.css 1 file
I do, Change all the same color chart
Help me please…sample attact
    Jason D.
    Jason D. answered on Jan 26, 2016 2:02 PM
    Hello Sulada,
    Which Infragistics product is this for? ASP.NET, IgniteUI, or something else? Also, you mention that you attached a sample but I only see the images. Is there some sample that you can send me?
      sulada sudjai
      sulada sudjai answered on Jan 27, 2016 2:29 AM
      T้his stylesheet file of me
      .ui-chart-palette-1
      /*border-color: rgb(128, 128, 128);
      border-color: rgba(128, 128, 128, .8);*/
      border-color: rgb(255, 255, 183);
      background-color: rgb(255, 255, 183);
      background-color: rgba(255, 255, 183, .8);
      .ui-chart-palette-2
      /*border-color: rgb(51, 51, 51);
      border-color: rgba(51, 51, 51, .8);*/ /*ดำ*/
      border-color: rgb(221, 255, 221);
      background-color: rgb(221, 255, 221);
      background-color: rgba(221, 255, 221, .8);
      .ui-chart-palette-3
      /*border-color: rgb(35, 128, 168);
      border-color: rgba(35, 128, 168, .8);*/
      border-color: rgb(255, 184, 166);
      border-color:rgb(255, 184, 166);
      background-color: rgb(255, 184, 166);
      background-color: rgba(255, 184, 166, .8);
      .ui-chart-palette-4
      /*border-color: rgb(24, 81, 112);
      border-color: rgba(24, 81, 112, .8);*/
      background-color: rgb(255, 202, 149);
      background-color: rgba(255, 202, 149, .8);
      .ui-chart-palette-5
      /*border-color: rgb(135, 153, 34);
      border-color: rgba(135, 153, 34, .8);*/
      background-color: rgb(255, 255, 255);
      background-color: rgba(255, 255, 255, .8);
      .ui-chart-axis
      border-color: #989EA3;
      background-color: #989EA3;
      .ui-chart-legend-items-list
      padding: 10px;
      margin: 5px;
      .ui-chart-legend-item-text
      vertical-align: text-bottom;
      .ui-chart-legend-item-badge
      vertical-align: baseline;
      .ui-chart-tooltip
      -moz-box-shadow: 5px 5px rgba(0,0,0,0.5);
      -webkit-box-shadow: 5px 5px rgba(0,0,0,0.5);
      .ui-chart-title{font-family:Tahoma;font-size:11px;color:#000000;margin:5px 0 5px 0} /*title*/
      .ui-chart-subtitle{font-family:Tahoma;font-size:10px;color:#BFBFBF;margin:0 0 5px 0} /*subtitle*/
      .ui-chart-area-fill-opacity{opacity:.7}
      .ui-chart-aligned-gridlines{visibility:visible}
      .ui-chart-axis-stroke,.ui-chart-axis-major-line{border-color:transparent}
      I want have many Color schemes graph in stylesheet
        Jason D.
        Jason D. answered on Jan 27, 2016 1:10 PM
        Hello Sulada,
        Thank you for this information. However, to properly assist you I need to know which Infragistics controls you are using. Are you using the IgniteUI igDataChart, the Infragistics for ASP.NET WebChart, or some other control?
        sulada sudjai
        sulada sudjai answered on Jan 28, 2016 2:56 AM
        Hello Jason D,
        I using  the Infragistics for ASP.NET WebChart
        sulada sudjai
        sulada sudjai answered on Jan 28, 2016 2:57 AM
        Hello Jason D,
        I using  the Infragistics for ASP.NET WebChart.
        Jason D.
        Jason D. answered on Jan 28, 2016 2:32 PM
        Sulada,
        The Infragistics for ASP.NET WebChart was not designed to really work with CSS for styling. Instead it has various style settings that you would apply through code:
        Chart Appearance
        Change the Chart's Look and Feel
        Assign Custom Colors to Chart Elements
        Customize Skins and Paint Elements
        If you really require it to come through a CSS file then what you would need to do is parse the CSS file to extract the settings on the server and then apply those settings to your charts through the code behind. For examples of how you might go about parsing the CSS please see the following StackOverflow discussion: http://stackoverflow.com/questions/5884844/how-can-i-read-css-properties-in-asp-net
sulada sudjai
10 years, 8 months ago
