Infragistics Community Forum / Web / Ignite UI for jQuery / How to format a date in a multi-column combobox
Rob
Rob asked on May 8, 2013 12:50 PM
I have a jQuery combobox in which I want to display a name column and a date column.
@(Html
.Infragistics()
.Combo()
.ID(“comboEvents”)
.FilteringType(ComboFilteringType.None)
.ValueKey(“eventId”)
.TextKey(“name”)
.DropDownMinHeight(50)
.Width(“300px”)
.DataSource(Url.Action(“EventListCombo”))
.ItemTemplate(“<div>${name} (${date})</div>”)
.DataBind()
.Render()
Obviously the date shows up as a JSON date (“/Date(1315540800000)/”).  How can I get the jQuery date format to work within the above itemtemplate?
    Josh
    Josh answered on May 1, 2012 11:33 PM
    Check out this post in Stack Overflow.  It involves using the native js Date object:
    http://stackoverflow.com/a/2316066/732673
      Rob
      Rob answered on May 2, 2012 5:50 PM
      Not too sure that's going to help me with IG's itemtemplate…
        Josh
        Josh answered on May 2, 2012 6:03 PM
        Correct, no, you can't use the method I linked to directly in IG's itemtemplate.  You'd convert the date values in your datasource using javascript, then send your datasource to igcombo with the dates already in an acceptable format.
        There may be some way to have IG's datasource recognize JSON dates and display them formatted in the way you like, but it's not immediately apparent to me from looking at their documentation.
        http://www.igniteui.com/help/api/2015.2/ig.datasource
    [Infragistics] Borislav Traykov answered on May 3, 2012 8:30 PM
    Hi Josh,As JoshNoe suggested, you will need to parse the serialized date from the server response.
    What I can recommend is to use a simple function for this task – for example:
    var parseToDate = function(val) {     return new Date(parseInt(val.replace(‘/Date(‘, ”).replace(‘)/’, ”), 10));};And if you want to format the dates you have just like the grid does, you will need to do this yourself as we don’t provide it as an out of the box.I’m partially lying to you here, because if you dig into the code of the igGrid, you will see that in order to apply column formatting, the igGrid relies on a function called $.ig.formatter() – it’s defined in the ig.util.js file and is meant to be internal, but I don’t see a reason why you shouldn’t use it.Basically the  $.ig.formatter() function is easy to use, because all you need is to call it with the first 3 parameters:
    1. the value that has to be formatted
    2. the type of the data (this corresponds to an igGrid column’s dataType)
    3. the format that you wish to apply  – you can pick from the values, available for the column format of the igGrid:
    I’ve attached an HTML sample page to this reply which illustrates my suggestion.Hope it helps you out1.
    Cheers and good luck!Borislav
      Josh
      Josh answered on May 4, 2012 6:04 PM
      Hi Josh,
      As psurobdude suggested, you will need to parse the serialized date from the server response.
      Just to be clear, psurobdude is looking for the answer, and I made the suggestion :).
        [Infragistics] Borislav Traykov answered on May 7, 2012 1:42 PM
        Point taken and correction made 😉
      Karl Costenbader
      Karl Costenbader answered on Apr 18, 2013 6:11 AM
      This no longer appears to work with the Infragistics templating engine. Is it possible to get an updated sample?
        [Infragistics] Borislav Traykov answered on Apr 21, 2013 5:16 PM
        Hi Karl,I’m not sure what the problem you mentioned looks like. Can you elaborate more on that?I’m attaching a fully functional updated version of my HTML sample so you can use it as a benchmark/playground.Cheers,BobbyPS: Note that the NetFlix OData service has been discontinued for public access since April 1st so I had to use Infragistics’ own OData service which we use for the official samples in the Samples Browser.
        Karl Costenbader
        Karl Costenbader answered on Apr 21, 2013 5:41 PM
        Sorry, I was having the same problem as the original poster: trying to format a "column" in a grid combo that contains a date in order to support internationalization.
        Your original solution executed two methods: igFormatter and parsetToDate in order to accomplish this:
        itemTemplate: … <p>${igFormatter(parseToDate(DateModified), 'date', 'dateTime')}</p> …
        However, I believe that this was written before the Infragistics templating engine was introduced which no longer appears to support this functionality. I can get methods to execute in the {{if portion of the template, but have not found a way to use a method in the content area.
        [Infragistics] Borislav Traykov answered on Apr 23, 2013 1:42 PM
        Hey Karl,Thanks for pointing me to the problem – I really missed the application of the igFormatter in my updated sample.You are also correct in your assessment of the ig Templating Engine: it doesn’t support functions due to performance reasons. I believe that this is stated in somewhere the help documentation as well.So the problem indeed becomes tricky as hell, so the solution I can give is to use a workaround.Instead of applying the date formatting functions in the itemTemplate, simply have the date values formatted before they are displayed.This means modifying the date values of the date property from the source data (in the igCombo’s dataBound event).Here’s the code I’m using:
        $('#comboIG').igCombo({
            filterExprUrlKey: null,
            filteringType: 'local',
            renderMatchItems: 'contains',
            responseDataKey: 'd.results',
            //valueKey: 'Name',
            valueKey: 'LastName',
            width: '300px',        //itemTemplate: "<div class=\'comboItemContainer\'><div class=\'empInfo\'><span class=\'empName\'>${Name}</span><p>${BirthDate}</p></div></div>",        itemTemplate: "<div class=\'comboItemContainer\'><div class=\'empInfo\'><span class=\'empName\'>${FirstName} ${LastName}</span><p>${BirthDate}</p></div></div>",	inputName: 'comboIG',
            //dataSource: 'http://labs.infragistics.com/igniteui/api/employees?callback=?', // OData v.3
            dataSource: 'http://services.odata.org/Northwind/Northwind.svc/Employees?$format=json&$callback=?', // OData v.1 or v.2
            dataBound: function(evt, ui) {
                var comboData = ui.dataSource.data();
                for(var i = 0, len = comboData.length; i < len; i++)
                    comboData[i]["BirthDateOriginal"] = comboData[i]["BirthDate"];
                    // Use in case your dates are returned by an ASP.NET JSON serializer. Comment the line below if you use the Infragistics Northwind OData service.
                    comboData[i]["BirthDate"] = igFormatter(parseToDate(comboData[i]["BirthDate"]), 'date', 'dateTime');
        Some explanations are in order:
        The official NorthWind OData service still uses the v.2 URI conventions and the default ASP.NET JSON serializer so the dates it serves are still in the format “\/Date(milliseconds)\/”. This is where the igFormatter and the parseTodate functions can be used in order to get the desired formatting.However, our Samples Browser’s Northwind OData service is actually ASP.NET WebAPI with OData attributes and so it adheres to version 3 of the OData standard and it uses the NewtonSoft JSON serializer. This combination of facts means that dates are served in the “dd/MM/YYYY” format which doesn’t require formatting (unless you wish to format your date in a different format).This is why I’ve commented out 3 lines of the code above – you can uncomment them and switch to our Samples Browser’s OData service to see the differences.
        Regardless of the used OData service used, I think it’s a good practice to have the original value of the date property just in case. This is why I’m backing each of those values in the BirthDateOriginal property.PS: Sorry for the temporary awful formatting of the sample code – the forum wanted to play a trick on me with that one.Hope this helps.-Bobby
        Karl Costenbader
        Karl Costenbader answered on Apr 29, 2013 2:31 AM
        Thanks for the detailed response. This got me thinking a bit and I was actually able to resolve a majority of the scenarios by formatting the data in the web server that generates the grid js since the thread that generates it is aware of the user's current culture.
        There are still some edge case scenarios where the data is updated from the browser, but I believe that we can handle these in the same way.
        I think it would be very beneficial if we could use the igGrid (or a subset of it) as the dropdown display portion of the combo columns (or add a new editor type that adds this support).
        I know that as soon as we release, our users are going to be clamoring for the capabilities that we took away in the upgrade from ultrawebgrid, namely the abilities to resize the columns, sort the column data, and possibly filter it (although this isn't hugely important). I think that we need to have a multi-column combo dropdown solution that treats columns as first class members rather than as afterthoughts.
        [Infragistics] Borislav Traykov answered on May 8, 2013 12:50 PM
        [quote user="Karl Costenbader"]I think it would be very beneficial if we could use the igGrid (or a subset of it) as the dropdown display portion of the combo columns (or add a new editor type that adds this support).[/quote] If you mean having the values of a grid column as either the text or value keys for an igCombo (in context of the igGridUpdating feature), then I've given my thoughts and suggestions on this below.
        If you have something else in mind, please let me know.
        [quote user="Karl Costenbader"]I know that as soon as we release, our users are going to be clamoring for the capabilities that we took away in the upgrade from ultrawebgrid, namely the abilities to resize the columns, sort the column data, and possibly filter it (although this isn't hugely important).[/quote]Column resizing,  sorting and filtering are all features that the igGrid currently possesses so unless you have something more specific in mind, I think you have those bases covered even right now.
        [quote user="Karl Costenbader"]I think that we need to have a multi-column combo dropdown solution that treats columns as first class members rather than as afterthoughts.[/quote] This can be accomplished with some development effort (yes, still treating the column data as afterthoughts when in the context of an igCombo editor). I've asked the team responsible for the igGrid to see if they can provide some out-of-the-box solution so that for example you can feed the entire set of values of a given igGrid column as the value or text keys of an igCombo editor.
        However, scenarios here can easily get complicated (imagine a grid with several thousand records and/or remote data) so they will need to get a strategy down before they start implementing any improvements. I've asked them to have a look at our other grids and some customer feedback (from the forums, actually) so they can be more aware as to what the outcomes of those improvements should be.
        Hope this helps!
        -Bobby
Rob
13 years, 6 months ago
Rob
Feb 25, 2026 9:39 AM
